DSMR Reader
The DSMR Reader integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to easily add all sensors that DSMR Reader (Dutch Smart Meter Requirements Reader) exposes to MQTT. It adds a separate sensor for every field in the MQTT topics which is named sensor_dsmr_<mqtt_topic>.
To use this DSMR Reader sensor integration, you need to have a DSMR Reader instance running and an MQTT broker to send sensor data through.
  1. Add the MQTT broker integration in Home Assistant, if you haven’t done so already
  2. Configure the MQTT broker in the DSMR Reader application
  3. Enable the following data sources in the DSMR Reader administration pages with the default mappings:
    • Day consumption: Split topic
    • Gas consumption: Split topic
    • Meter Statistics: Split topic
    • Quarter-hour peak consumption: Split topic
    • Telegram: Split topic
To add the DSMR Reader device to your Home Assistant instance, use this My button:
DSMR Reader can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select DSMR Reader.
Configuring the energy dashboard
It is most advisable to not use the “total” and “daily” sources. The regular “reading” sensors provide the most stable source of data for Home Assistant to use. These MQTT values are part of the “Telegram: Split topic” MQTT values within DSMR Reader, so make sure to enable them.
Section Sensors to configure
Grid consumption Low tariff usage, High tariff usage
Return to grid Low tariff returned, High tariff returned
Gas consumption Gas meter usage
Difference with the DSMR integration
This integration relies on the presence of an existing DSMR Reader application setup. It processes the events triggered by the MQTT publishing feature to create sensor entities within Home Assistant. This integration uses the data published on the MQTT broker, no matter how or where the application is installed. By comparison, the DSMR integration connects directly to the smart meter within Home Assistant and doesn’t use the DSMR Reader application.
