devolo Home Control
devolo Home Control is a Z-Wave ecosystem with a Z-Wave to IP gateway in the center. The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control devices connected to the gateway.
To add the devolo Home Control hub to your Home Assistant instance, use this My button:
devolo Home Control can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select devolo Home Control.
Email / mydevolo ID
Email address you used to register the central unit at mydevolo.
Password
Password of your mydevolo account.
Note
Your mydevolo account is only used to acquire local credentials. Afterward, communication is completely local as long as the gateway is within the same network.
Supported devices and functions
Switches
The integration provides support for the following Z-Wave devices:
  • devolo Metering Plug v1
  • devolo Metering Plug v2
  • devolo Switch FM
  • Qubino Flush 1 Relay
  • Qubino Flush 1D Relay
  • Fibaro Wall Plug
  • Fibaro Double Relay Switch
Binary sensors
  • devolo Door/Window Contact
  • devolo Flood Sensor
  • devolo Key-Fob Switch
  • devolo Motion Sensor
  • devolo Smoke Detector
  • devolo Wall Switch
  • Fibaro Floor Sensor
  • Fibaro Motion Sensor
  • Fibaro Smoke Sensor
The integration provides support for the following features:
  • Overload alarm sensor of various switches
  • Sensors I2 and I3 of devolo and Qubino flush mounted relays
Cover
  • devolo Shutter FM
  • Qubino Flush Shutter
Climate
  • devolo Radiator Thermostat
  • Danfoss Living Connect Z Radiator Thermostat
Lights
  • devolo Dimmer FM
  • Qubino Flush Dimmer
Sensor
  • Temperature and brightness of devolo Sensors, that support it
  • Consumptions of devolo and Qubino devices, that support it
  • Voltage of devolo Metering Plug v2
Siren
  • devolo Siren
  3. Next to the entry, select the three-dot menu. Then, select Delete.
