MQTT device tracker
The mqtt
device tracker platform allows you to define new device_trackers through manual YAML configuration in configuration.yaml
and also to automatically discover device_trackers using the MQTT Discovery protocol.
To use this device tracker in your installation, add the following to your configuration.yaml
file:
mqtt:
- device_tracker:
state_topic: "location/annetherese"
- device_tracker:
state_topic: "location/paulus"
A list of MQTT topics subscribed to receive availability (online/offline) updates. Must not be used together with availability_topic
The payload that represents the available state.
The payload that represents the unavailable state.
When availability
is configured, this controls the conditions needed to set the entity to available
. Valid entries are all
, any
, and latest
. If set to all
, payload_available
must be received on all configured availability topics before the entity is marked as online. If set to any
, payload_available
must be received on at least one configured availability topic before the entity is marked as online. If set to latest
, the last payload_available
or payload_not_available
received on any configured availability topic controls the availability.
Defines a template to extract device’s availability from the availability_topic
. To determine the devices’s availability result of this template will be compared to payload_available
and payload_not_available
The MQTT topic subscribed to receive availability (online/offline) updates. Must not be used together with availability
Information about the device this device tracker is a part of that ties it into the device registry. At least one of identifiers or connections must be present to identify the device.
A link to the webpage that can manage the configuration of this device. Can be either an http://
, https://
or an internal homeassistant://
URL.
A list of connections of the device to the outside world as a list of tuples [connection_type, connection_identifier]
. For example the MAC address of a network interface: "connections": [["mac", "02:5b:26:a8:dc:12"]]
A list of IDs that uniquely identify the device. For example a serial number.
Defines a template to extract the JSON dictionary from messages received on the json_attributes_topic
. Usage example can be found in MQTT sensor documentation.
The MQTT topic subscribed to receive a JSON dictionary message containing device tracker attributes. This topic can be used to set the location of the device tracker under the following conditions:
- If the attributes in the JSON message include
longitude
,latitude
, andgps_accuracy
(optional). - If the device tracker is within a configured zone.
If these conditions are met, it is not required to configure state_topic
Be aware that any location message received at state_topic
overrides the location received via json_attributes_topic
until a message configured with payload_reset
is received at state_topic
. For a more generic usage example of the json_attributes_topic
, refer to the MQTT sensor documentation.
The payload value that represents the ‘home’ state for the device.
The payload value that represents the ‘not_home’ state for the device.
The payload value that will have the device’s location automatically derived from Home Assistant’s zones.
Attribute of a device tracker that affects state when being used to track a person. Valid options are gps
, router
, bluetooth
, or bluetooth_le
The MQTT topic subscribed to receive device tracker state changes. The states defined in state_topic
override the location states defined by the json_attributes_topic
. This state override is turned inactive if the state_topic
receives a message containing payload_reset
. The state_topic
can only be omitted if json_attributes_topic
is used.
An ID that uniquely identifies this device_tracker. If two device_trackers have the same unique ID, Home Assistant will raise an exception.
Examples
Using the discovery protocol
The device_tracker can be created via publishing to a discovery topic that follows the following MQTT Discovery topic name format: <discovery_prefix>/device_tracker/[<node_id>/]<object_id>/config
You can use the command line tool mosquitto_pub
shipped with mosquitto
or the mosquitto-clients
package to send MQTT messages.
To create the device_tracker:
mosquitto_pub -h 127.0.0.1 -t homeassistant/device_tracker/a4567d663eaf/config -m '{"state_topic": "a4567d663eaf/state", "name": "My Tracker", "payload_home": "home", "payload_not_home": "not_home"}'
To set the state of the device tracker to “home”:
mosquitto_pub -h 127.0.0.1 -t a4567d663eaf/state -m 'home'
To set the state of the device tracker to a named location:
mosquitto_pub -h 127.0.0.1 -t a4567d663eaf/state -m 'location_name'
If the device supports GPS coordinates then they can be sent to Home Assistant by specifying an attributes topic (i.e. “json_attributes_topic”) in the configuration payload:
- Attributes topic:
a4567d663eaf/attributes
- Example attributes payload:
Example message to be received at topic a4567d663eaf/attributes
"latitude": 32.87336,
"longitude": -117.22743,
"gps_accuracy": 1.2
To create the device_tracker with GPS coordinates support:
mosquitto_pub -h 127.0.0.1 -t homeassistant/device_tracker/a4567d663eaf/config -m '{"json_attributes_topic": "a4567d663eaf/attributes", "name": "My Tracker"}'
Using state_topic
is optional when using json_attributes_topic
to determine the state of the device tracker.
To set the state of the device tracker to specific coordinates:
mosquitto_pub -h 127.0.0.1 -t a4567d663eaf/attributes -m '{"latitude": 32.87336, "longitude": -117.22743, "gps_accuracy": 1.2}'
YAML configuration
The following example shows how to configure the same device tracker through configuration.yaml
mqtt:
- device_tracker:
state_topic: "a4567d663eaf/state"
payload_home: "home"
payload_not_home: "not_home"
