Cielo Home
The Cielo Home integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control Cielo devices directly from Home Assistant, using the cloud-based Cielo Connect API.
Supported devices
The Cielo Home integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] supports the following devices.
  • Cielo Breez Max: Smart thermostat for mini-splits.
  • Cielo Breez Edge Pro: Smart thermostat for mini-splits.
  • Cielo Thermostat Eco: Smart thermostat for central HVAC systems.
  • Cielo Smart Thermostat: Smart thermostat for central HVAC systems.
Before integrating the Cielo devices with Home Assistant, ensure that:
  • Your Cielo device is already registered in the Cielo Home app.
  • The device is among the supported devices listed above.
  • The device has a configured remote (automatically or manually).
  • Your Home Assistant server has internet access.
  • Before proceeding, ensure the Cielo device is fully compatible with Home Assistant.
Important API key rules
To safeguard security and prevent unauthorized access, Cielo enforces the following API security restrictions:
  • Each API key can be used only once.
  • A new API key cannot be generated until the current one is revoked.
  • You may generate a maximum of 3 keys per month.
  • Once a new API key is generated, wait 60 seconds for it to be displayed on the screen.
  • Revoking an API key will disconnect Home Assistant immediately or within about a minute.
Obtaining an API key
  1. Visit the Cielo Web Portal.
  2. Open the Menu by selecting the hamburger menu icon at the top left side.
  3. Select Home Assistant from the sidebar.
  4. The API key will be displayed. Copy the API key from the dialog.
Tip
If the message This key is already used appears, you must first revoke the old key before generating a new one.
To add the Cielo Home hub to your Home Assistant instance, use this My button:
  • From the list, select Cielo Home.
If authentication succeeds, Home Assistant will automatically create the climate and sensor entities for all supported Cielo devices in your account.
Note
If you add or set up a new Cielo device after configuring the integration in Home Assistant, you must reload the integration:
  1. Go to Settings > Devices & services.
  2. Select Cielo Home and in the right corner, select the three dots menu.
  3. Select Reload.
Supported functionality
Each supported device exposes at least one climate entity.
Note
Depending on device support, some entities might not be available as the device does not support them.
Climates
The climate platform integrates the compatible Cielo devices into Home Assistant, allowing control through its user interface.
Cielo Breez Max & Cielo Breez Edge Pro
  • HVAC modes (varies by device): Heat, Cool, Dry, Fan, Auto, Off
  • Temperature control: Provide a target temperature where applicable.
  • Fan modes: Provide a fan mode if applicable.
  • Vertical swing position: Provide a vertical swing position where applicable.
  • Presets: Home, Away, Sleep, & Pets (where supported & defined)
Note
Some fan modes or swing positions depend on the device’s remote configuration.
Cielo Smart Thermostat & Cielo Smart Thermostat Eco
  • HVAC modes (varies by equipment): Cool, Auto, Heat, Off
  • Temperature control: Set the temperature setpoint.
  • Presets: Home, Away, Sleep & pets (where supported and defined)
Sensors
Each supported device also exposes sensor entities that appear under the same device as the climate entity:
  • Temperature: Reports the current indoor temperature from the device. The unit (°C or °F) follows the device setting.
  • Humidity: Reports the current humidity from the device, in percent.
Data updates
This integration relies on cloud pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more], with data refreshed approximately every 120 seconds (2 minutes). If the Cielo API or your device becomes unavailable, Home Assistant will automatically retry.
  • Manual changes made in the Cielo Home app or via IR remote are synced automatically on the next poll.
Note
If the device is added after the integration, you need to reload the Cielo Home integration.
Actions
This integration does not provide any custom service actions. All controls are performed using the standard Home Assistant climate services.
API limitations
  • API key cannot be reused.
  • Revoking an API key will immediately disconnect Home Assistant.
  • You can generate a maximum of three API keys within last 30 days.
This integration relies on an active internet connection and access to the Cielo Home API. Here are a few things to check before raising an issue:
  • Confirm that your Home Assistant has internet access.
  • Verify that your Cielo device is online by checking its status in the Cielo Home app.
  • Ensure that the device’s remote configuration is complete. Devices without remotes will not expose HVAC modes.
  • Check that your API key is still valid and hasn’t been revoked.
  • Reconfigure the integration and provide a freshly generated key.
  • Try refreshing the entities manually in Home Assistant.
If devices still fail to load after these steps, please contact Cielo Tech Support.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
Note
Optional: Revoke your API key in the Cielo Home Web Portal.
