Casper Glow
The Casper Glow integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control your Casper Glow light from Home Assistant over Bluetooth. The Casper Glow is a portable dimmable light designed as a sleep aid, featuring a gentle dimming sequence that gradually lowers brightness to help you fall asleep. You can incorporate it into your bedtime automations to control brightness levels.
Supported devices
The following devices are supported:
- Casper Glow (identified as “Jar” over Bluetooth)
Before setting up the integration, make sure:
- Your Home Assistant host has a Bluetooth adapter.
- The Casper Glow is powered on and within Bluetooth range.
To add the Casper Glow device to your Home Assistant instance, use this My button:
From the list, select Casper Glow.
Supported functionality
Entities
The Casper Glow integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following entities.
Binary sensors
Dimming paused
- Description: Indicates whether the Glow’s dimming sequence is currently paused.
Charging
- Description: Indicates whether the Glow is currently charging.
Buttons
Pause dimming
- Description: Pauses dimming, holding the current brightness level until resumed.
Resume dimming
- Description: Resumes dimming from where it left off.
Lights
Casper Glow
- Description: Controls the on/off state and brightness of the Glow light. Brightness is mapped to five levels.
Sensors
Battery
- Description: Reports the current battery level of the Glow as a percentage.
Dimming end time (disabled by default)
- Description: Shows the projected time when the current dimming sequence will end. This value is a timestamp that updates only when there is a significant change during a poll interval. Such as pausing or resuming dimming, or manually adjusting the physical light.
Selects
Dimming time
- Description: Configures how long the dimming sequence lasts before the light turns off. You can choose between 15, 30, 45, 60, or 90 minutes. The new dimming time takes effect the next time the light is turned on.
Examples
Bedtime routine
Start a dimming sequence at a set time each night. This blueprint lets you pick your bedtime and how long the light takes to dim, so your Glow is ready when you are.
Prefer to configure this automation manually? Use the YAML below.
Automation YAML
Replace the placeholder values with values from your Home Assistant instance.
alias: Casper Glow bedtime routine
variables:
glow_device: YOUR_GLOW_DEVICE
triggers:
- trigger: time
at: YOUR_BEDTIME
actions:
- action: select.select_option
entity_id: >
{{ device_entities(glow_device)
| select('match', 'select\\..*')
| first }}
option: '30'
- action: light.turn_on
entity_id: >
| select('match', 'light\\..*')
| first }}
Pause on motion
Keep the light from dimming while you’re still up. This blueprint pauses the dimming sequence whenever motion is detected, so the light holds its brightness until you settle in.
Automation YAML
alias: Pause Casper Glow on motion
variables:
glow_light: YOUR_GLOW_LIGHT
pause_button: >
{{ device_entities(device_id(glow_light))
| select('match', 'button\\.')
| select('search', 'pause')
| first }}
triggers:
- trigger: state
entity_id: YOUR_MOTION_SENSOR
to: "on"
conditions:
- condition: state
entity_id: YOUR_GLOW_LIGHT
state: "on"
actions:
- action: button.press
entity_id: "{{ pause_button }}"
Turn on and hold at nightlight level
Turn on the Glow and let it dim down to a soft nightlight, then hold it there. This blueprint starts the dimming sequence and automatically pauses it when a set number of minutes remain, leaving a gentle glow in the room through the night.
The sensor.jar_dimming_end_time sensor is disabled by default. You must enable it manually for this blueprint to work correctly.
Automation YAML
alias: Turn on Casper Glow and pause at nightlight level
variables:
dimming_minutes: '15'
pause_at_remaining: 10
light_entity: >
{{ device_entities(glow_device) | select('match', 'light\\.') | first }}
select_entity: >
{{ device_entities(glow_device) | select('match', 'select\\.') | first }}
pause_button: >
| first }}
sensor_entity: >
| select('match', 'sensor\\.')
| select('search', 'dimming_end_time')
| first }}
triggers:
- trigger: time
at: YOUR_BEDTIME
actions:
entity_id: "{{ select_entity }}"
option: '15'
entity_id: "{{ light_entity }}"
- wait_for_trigger:
- trigger: template
value_template: >-
{% set end = states(sensor_entity) | as_datetime %}
{% if end is not none %}
{{ ((end - now()).total_seconds() / 60) | round(0) <= pause_at_remaining | int }}
{% else %}
false
{% endif %}
timeout:
minutes: "{{ dimming_minutes | int }}"
continue_on_timeout: false
Data updates
The Casper Glow integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] detects the device through passive Bluetooth advertisements. All state updates are retrieved by actively pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the device every 30 seconds — for example, to detect changes made directly on the light or through the Casper app.
Known limitations
- Brightness is limited to five discrete levels. The integration maps these to the Home Assistant 0-255 brightness scale, snapping to the nearest supported level.
- The integration communicates over Bluetooth, so the light must remain within range of the Home Assistant Bluetooth adapter.
- Only one Bluetooth connection to the Glow can be active at a time. If the Casper app is connected, Home Assistant may not be able to reach the device.
The device is not discovered
Make sure the Glow light is powered on and within Bluetooth range. If it still doesn’t appear, try toggling the light off and on by flipping it over. Ensure no other Bluetooth device (like the Casper app) is actively connected to it.
The light shows as unavailable
This typically means the Bluetooth connection was lost. Check that the light is powered on and within range. Moving the light closer to the Bluetooth adapter may help.
Resetting the light
If the light remains unresponsive, a reboot or factory reset may help.
- To reboot, hold both buttons on the Glow until it briefly turns on. This takes about 30 seconds.
- To factory reset the Glow, press one of the buttons 6 times while holding the other button down.
- This returns the device to default settings and removes it from any configured Glow light groups (configured outside Home Assistant in the Casper app).
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
