Bryant Evolution
The Bryant Evolution integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control Bryant Evolution HVAC systems.
  • It requires that a System Access Module be connected to the HVAC system (for example, a Bryant SYSTXBBRCT01).
To install:
  1. Connect the System Access Module to the device running Home Assistant, for example, by using an RS-232-to-USB adapter.
  2. Install the Bryant Evolution integration in Home Assistant, passing the name of the serial port to which the device is connected (for example, /dev/ttyUSB0)
To add the Bryant Evolution device to your Home Assistant instance, use this My button:
  • From the list, select Bryant Evolution.
