Azure Storage
This integration allows you to use Azure storage accounts for use with Home Assistant Backups.
To add the Azure Storage service to your Home Assistant instance, use this My button:
  • From the list, select Azure Storage.
Storage account name
The name of the storage account. Only the name, nothing else.
Container name
Blob container name to store the backups. If the container does not exist, it will be created. Defaults to hass-backups.
Storage account key
One of the two storage account keys. Used to authenticate against the storage account
Known Limitations
  • Only storage accounts that have a default URL storageaccountname.blob.core.windows.net are supported at this point
  • Since only key based authentication is possible, this has to be enabled in your storage account.
  3. Next to the entry, select the three-dot menu. Then, select Delete.
Authentication failure
Check that your storage account allows Shared Key access.
