Assist pipeline
The Assist pipeline integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the foundation for the Assist voice assistant in Home Assistant.
For most users, there is no need to install this integration manually. The Assist pipeline integration is part of the default configuration and is set up automatically if needed by other integrations. If you are not using the default integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more], you need to add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
assist_pipeline:
YAML
For more information, refer to the procedure on configuring a pipeline.
