Apollo Automation
Apollo automation
Apollo Automation devices work locally and integrate seamlessly with the ESPHome integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] in Home Assistant. As all connectivity is done locally, status updates and device control from Home Assistant happen instantly.
Support for devices by Apollo Automation in Home Assistant is provided by the ESPHome integration.
Apollo Automation devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the ESPHome integration.
To add the Apollo Automation brand to your Home Assistant instance, use this My button:
From the list, select Apollo Automation.
Usage information
For more documentation on how to use Apollo Automation in Home Assistant, please refer to the ESPHome integration documentation page.
Supported devices
The following devices are known to be supported by the integration. They are certified under the Works with Home Assistant program.
MTR-1 Multi-Target Radar Multisensor For Home Assistant (LD2450)
- A tiny, but powerful radar-based (mmWave) presence sensor that can pack in many other sensors. -
MSR-2 mmWave Multisensor For Home Assistant (LD2410B)
- An even smaller multisensor that is the successor of the initial community feedback-driven design. -
AIR-1 Air Quality Sensor For Home Assistant
- A small air quality multisensor that can be extended to incorporate a huge variety of sensors.
