Android TV Remote
The Android TV Remote integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control an Android TV and launching apps. For this to work, the Android TV device needs to have Android TV Remote Service which is pre-installed on most devices (Fire TV devices are a notable exception).
For a quick introduction on how to get started with Android TV Remote, check out this video:
To add the Android TV Remote device to your Home Assistant instance, use this My button:
Android TV Remote can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Android TV Remote.
Options
To define options for Android TV Remote, follow these steps:
In Home Assistant, go to Settings > Devices & services.
If multiple instances of Android TV Remote are configured, choose the instance you want to configure.
On the card, select the cogwheel
. - If the card does not have a cogwheel, the integration does not support options for this device.
Edit the options, then select Submit to save the changes.
Here you can define applications where the keys are app IDs and the values are app names and icons that will be displayed in the UI.
Media player
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] adds a media_player with basic playback and volume controls. The media player provides volume information and display name of current active app on the Android TV. Due to API limitations, the integration will not display the playback status. It is recommended to use this integration together with Google Cast integration. Two media players can be combined into one using the Universal Media Player integration. See Using with Google Cast section for more details.
Using the media_player.play_media actionAn action makes Home Assistant do something, for example, turn on a light, send a notification, or activate a scene. Automations and scripts run a list of actions. [Learn more], you can launch applications, switch channels, and start activities via Deep Links. Only app, url and channel media types are supported.
Launching activities
The most reliable way to launch an app, or open a specific screen within it, is with a deep link supported by the app.
Examples of deep links for popular applications:
| App | Deep link |
| YouTube |
https://www.youtube.com or vnd.youtube:// or vnd.youtube.launch://
| Netflix |
https://www.netflix.com/title/<title ID>?source=30 or netflix://
| Prime Video | https://app.primevideo.com |
| Disney+ | https://www.disneyplus.com |
| Plex | plex:// |
| Twitch |
twitch://home [home, stream, game, video, clip, search, browse, channel, user]
The Netflix app opens a specific title only when the link ends with ?source=30. Without it, the app opens, but shows or resumes the last watched title. The title ID is the number in the title’s address on netflix.com.
Example:
# Open a specific YouTube video:
media:
media_content_type: url
media_content_id: https://www.youtube.com/watch?v=dQw4w9WgXcQ
entity_id: media_player.living_room_tv
Launching apps
If an app doesn’t have a deep link, or the device doesn’t have the Google Play Store, you can try to launch it directly by its application ID (package name).
The app doesn’t need to exist in the Google Play Store.
If it exists, you can find the application ID in the URL of the app’s Google Play Store listing.
For example, if the URL of an app page is play.google.com/store/apps/details?id=com.example.app123, the application ID is com.example.app123.
The application ID is also displayed in the media player card when you launch the application on the device.
A change to the Google Play Store is currently preventing this method from working for many apps. If launching by application ID doesn’t work, use a deep link instead.
Examples of application IDs for popular applications:
| App | App ID |
| YouTube | com.google.android.youtube.tv |
| Netflix | com.netflix.ninja |
| Prime Video | com.amazon.amazonvideo.livingroom |
| Disney+ | com.disney.disneyplus |
| Plex | com.plexapp.android |
| Kodi | org.xbmc.kodi |
| Twitch | tv.twitch.android.app |
Example:
# Launch the YouTube app
media:
media_content_type: app
media_content_id: com.google.android.youtube.tv
Switch channels
You can pass the channel number to switch channels. The channel number must be an integer.
Example:
# Change channel to number 15:
media:
media_content_type: channel
media_content_id: 15
Android TV Remote integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides information about the power status of the device and gives you the ability to control playback. However, it does not provide information about the currently playing content (media title, duration, play/pause state, etc.). In turn, Google Cast integration does not provide reliable information about the power status of the device (e.g. on Android TV Home Screen) and does not allow you to control playback in Android apps without MediaSession support. However, it can display full information about the content being played in supported apps. For convenience, you can combine two media players into one using Universal Media Player integration. Universal Media Player will automatically select the appropriate active media player entity.
Example YAML configuration
Replace media_player.living_room_tv_remote with your Android TV Remote media player entity ID.
Replace media_player.living_room_tv_cast with your Google Cast media player entity ID.
media_player:
- platform: universal
unique_id: living_room_tv
device_class: tv
children:
- media_player.living_room_tv_remote
- media_player.living_room_tv_cast
browse_media_entity: media_player.living_room_tv_cast
commands:
turn_off:
action: media_player.turn_off
entity_id: media_player.living_room_tv_remote
turn_on:
action: media_player.turn_on
volume_up:
action: media_player.volume_up
volume_down:
action: media_player.volume_down
Remote
The remote allows you to send key commands and text as input to your Android TV device with the remote.send_command action.
The entity has the current_activity attribute that shows the current foreground app on the Android TV.
You can pass a deep link, or the application ID shown in this current_activity, as activity in the remote.turn_on action to launch that app.
Launching by application ID currently doesn’t work reliably for many apps due to a Google Play Store change, so use a deep link when you have one.
List of the most common commands
Navigation:
- DPAD_UP
- DPAD_DOWN
- DPAD_LEFT
- DPAD_RIGHT
- DPAD_CENTER
- BUTTON_A
- BUTTON_B
- BUTTON_X
- BUTTON_Y
- BACK
Volume Control:
- VOLUME_DOWN
- VOLUME_UP
- VOLUME_MUTE
- MUTE
Media Control:
- MEDIA_PLAY_PAUSE
- MEDIA_PLAY
- MEDIA_PAUSE
- MEDIA_NEXT
- MEDIA_PREVIOUS
- MEDIA_STOP
- MEDIA_RECORD
- MEDIA_REWIND
- MEDIA_FAST_FORWARD
TV Control:
- 0
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- DEL
- ENTER
- CHANNEL_UP
- CHANNEL_DOWN
- F1
- F2
- F3
- F4
- F5
- F6
- F7
- F8
- F9
- F10
- F11
- F12
- TV
- PROG_RED
- PROG_GREEN
- PROG_YELLOW
- PROG_BLUE
Other:
- BUTTON_MODE
- EXPLORER
- MENU
- HOME
- INFO
- GUIDE
- TV_TELETEXT
- CAPTIONS
- DVR
- MEDIA_AUDIO_TRACK
- SETTINGS
- SEARCH
- ASSIST
- POWER
Sending key commands
Whether a command does something depends on your Android TV device, its firmware, and the app in the foreground. Some devices remap or ignore certain keys, so a command like GUIDE or MENU might do nothing or trigger a different action than you expect. The commands are sent to your device as is, so Home Assistant cannot change how your device reacts to them.
Pass any of the most common commands in the list above as command in the remote.send_command action.
# Open the currently selected item on the Android TV
action: remote.send_command
command: DPAD_CENTER
entity_id: remote.living_room_tv
To trigger the long-press behavior of a key, supply hold_secs in seconds. Fractional seconds, like 0.5 for half a second, are supported. The integration will press the key, wait the given duration, and then release it as a single atomic call.
# Long press on the currently selected item on the Android TV
hold_secs: 0.5
Press and release as separate events
When a button, controller, or frontend card already emits separate press and release events, you can forward each one to the TV as its own service call by prefixing the command with a direction. Each call sends exactly one event, so the release fires when your source event fires, not when a fixed hold_secs timer ends.
The accepted prefixes are start_long: (press down), end_long: (release up), and short: (the default). Prefixes are case-insensitive. Plain commands without a prefix continue to send a short tap. When both a prefix and hold_secs are supplied, hold_secs takes precedence.
# Press down on DPAD_DOWN. Returns immediately, the key stays "held".
command: "start_long:DPAD_DOWN"
# Release DPAD_DOWN. Sent later, when the user lets go.
command: "end_long:DPAD_DOWN"
Sending text input
To send text as keyboard input, prefix the value of command with text:. The text after the prefix is delivered to whichever input field is currently focused on the Android TV.
# Send "Never Gonna Give You Up" as keyboard input text to the selected input field
command: text:Never Gonna Give You Up
Launching apps and activities
Use remote.turn_on with the activity field to launch an app or open a specific deep link. The value can be an application ID (see the Launching apps section), a URL, or a scheme supported by the target app.
# Launch YouTube
action: remote.turn_on
activity: https://www.youtube.com
activity: https://www.youtube.com/watch?v=dQw4w9WgXcQ
Dashboard example
You have to manually create buttons in Lovelace to send commands to the Android TV device or launch apps on it.
Below is an example for you to start with. Many of the buttons support long press.
YAML Lovelace example
Add a Manual card with the following code.
Replace all instances of living_room_tv with your entity ID.
- To use the
replace allfunctionality, inside the code editor, pressctrl+F(orcommand+Fon Mac).
type: vertical-stack
cards:
- type: entities
entities:
- entity: remote.living_room_tv
- square: true
columns: 3
type: grid
cards:
- type: button
show_icon: false
tap_action:
action: none
hold_action:
action: none
- type: button
icon: mdi:arrow-up-bold
tap_action:
action: perform-action
perform_action: remote.send_command
command: DPAD_UP
hold_action:
action: none
- type: button
show_icon: false
tap_action:
action: none
hold_action:
action: none
- type: button
icon: mdi:arrow-left-bold
tap_action:
command: DPAD_LEFT
hold_action:
action: none
- type: button
icon: mdi:circle
tap_action:
hold_action:
hold_secs: 0.5
- type: button
icon: mdi:arrow-right-bold
tap_action:
command: DPAD_RIGHT
hold_action:
action: none
- type: button
tap_action:
command: BACK
hold_action:
command: BACK
hold_secs: 0.5
- type: button
icon: mdi:arrow-down-bold
tap_action:
command: DPAD_DOWN
hold_action:
action: none
- type: button
icon: mdi:home-outline
tap_action:
command: HOME
hold_action:
command: HOME
hold_secs: 0.5
- square: false
columns: 3
type: grid
cards:
- type: button
icon: mdi:skip-previous
tap_action:
command: MEDIA_PREVIOUS
hold_action:
command: MEDIA_REWIND
- type: button
icon: mdi:play-pause
tap_action:
command: MEDIA_PLAY_PAUSE
hold_action:
command: MEDIA_STOP
- type: button
icon: mdi:skip-next
tap_action:
command: MEDIA_NEXT
hold_action:
command: MEDIA_FAST_FORWARD
- type: button
icon: mdi:volume-off
tap_action:
command: MUTE
hold_action:
action: none
- type: button
icon: mdi:volume-medium
tap_action:
command: VOLUME_DOWN
hold_action:
action: none
- type: button
icon: mdi:volume-high
tap_action:
command: VOLUME_UP
hold_action:
action: none
- square: false
columns: 4
type: grid
cards:
- type: button
icon: mdi:youtube
tap_action:
perform_action: remote.turn_on
hold_action:
action: none
- type: button
icon: mdi:netflix
tap_action:
activity: netflix://
hold_action:
action: none
- type: picture
image: >-
https://upload.wikimedia.org/wikipedia/commons/thumb/1/11/Amazon_Prime_Video_logo.svg/450px-Amazon_Prime_Video_logo.svg.png
tap_action:
activity: https://app.primevideo.com
hold_action:
action: none
- type: picture
image: >-
https://upload.wikimedia.org/wikipedia/commons/thumb/3/3e/Disney%2B_logo.svg/440px-Disney%2B_logo.svg.png
tap_action:
activity: https://www.disneyplus.com
hold_action:
action: none
- type: entity
attribute: current_activity
- type: media-control
Limitations and known issues
- Launching apps by their application ID (as opposed to a deep link) currently doesn’t work for many apps due to a Google Play Store change. Use a deep link instead when one is available.
- The integration doesn’t work with Fire TV devices because they are missing the Android TV Remote Service. Attempts to sideload it haven’t been successful.
- If you cannot use the Google TV mobile app or the Google Home mobile app to send commands to the device, you cannot send commands with this integration either.
- Commands don’t work on Netflix. They don’t work from the Google TV mobile app or the Google Home mobile app either.
- Some devices, like Xiaomi, become unavailable after they are turned off and can’t be turned on with this integration.
- Some devices, like TCL, become unavailable after they are turned off, unless you activate the Screenless service. To activate it, go to Settings > System > Power and energy > Screenless service, and activate it.
- Some devices experience disconnects every 15 seconds. This is typically resolved by rebooting the Android TV device after the initial setup of the integration.
- If you are not able to connect to the Android TV device, or are asked to pair it again and again, try force-stopping the Android TV Remote Service and clearing its storage. On the Android TV device, go to Settings > Apps > Show system apps. Then, select Android TV Remote Service > Storage > Clear storage. You will have to reboot Home Assistant to restart pairing with the Android TV.
- Some onscreen keyboards enabled by TV manufacturers do not support concurrent virtual and onscreen keyboard use. This presents whenever a text field is selected, such as “search” where a constant use the keyboard on your mobile device will show, preventing you from opening the onscreen keyboard to type. This can be overcome by either disabling your 3rd party keyboard and using the default Gboard keyboard or by deselecting Enable IME in the Configure page of the integration.
- If you can’t turn on your Nvidia Shield device, go to Settings > Remotes & accessories > Simplified wake buttons and disable the following options: SHIELD 2019 Remote: Wake on power and Netflix buttons only and Controllers: Wake on NVIDIA or logo buttons only.
Data updates
Android TV devices push data directly to Home Assistant, enabling immediate updates for device state changes such as power state, volume, and current active app. But the media player entity has assumed playback state since the Android TV Remote API doesn’t provide playback status.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
