Airthings BLE
Integrates Airthings BLE sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] into Home Assistant.
Airthings
Requires Airthings hardware and a compatible Bluetooth dongle.
To add the Airthings BLE integration to your Home Assistant instance, use this My button:
From the list, select Airthings BLE.
The Airthings BLE integration will automatically discover devices once the Bluetooth integration is enabled and functional. This will include the device name and its serial number.
There are two ways of retrieving the 10-digit serial number of a Wave device:
- At the back of the device, located under the magnetic backplate.
- Airthings app: Device settings -> Device info -> Serial Number
This integration uses the last 6 digits of the serial number.
Supported devices
- Wave gen. 1
- Wave Radon
- Wave Mini
- Wave Plus
- Wave Enhance
Sensors
Sensor entities added to Home Assistant, depending on the device model:
- Humidity
- Illuminance
- Pressure (relative depending on home elevation)
- Radon 1-day and longterm average, as well as levels
- Temperature
- VOC
- Co2
- Battery
