Agent DVR
Agent DVR is a free* software DVR solution for Windows 10, Mac and Linux. Agent DVR runs as a service or console application and can access and control a huge range of third party cameras with advanced motion detection, including DeepStack integration for object recognition. The iSpyConnect website provides secured (SSL) remote access without port forwarding needed.
You can add Agent DVR via integrations using the IP address and port of the server, like: http://192.168.1.3:8090/. If you have “Protect API” turned on in your Agent DVR server configuration, you can supply the username and password as part of the URL, for example, http://username:[email protected]:8090.
To add the Agent DVR integration to your Home Assistant instance, use this My button:
  • From the list, select Agent DVR.
Important
Please ensure you are using Agent DVR v2.6.1.0 +
Alarm control panel
Reports on the current alarm status and can be used to arm and disarm the system.
Actions
Once loaded, the agent_dvr integration will expose actions that can be used. The entity_id action attribute can specify one or more specific cameras.
Available actions: enable_alerts, disable_alerts, start_recording, stop_recording, turn_on, turn_off, toggle, enable_motion_detection,disable_motion_detection
Action enable_alerts/disable_alerts
These actions enable or disable the device’s alert events within Agent DVR.
Data attribute Optional Description
entity_id no Name(s) of entities, e.g., camera.living_room_camera.
Action start_recording/stop_recording
These actions start or stop the device recording.
Action turn_on/turn_off/toggle
These actions turn on, off or toggle the device enabled state within Agent DVR
Iframe
*Agent offers additional services like secured remote access (without port forwarding) and cloud uploads via a subscription service.
