Matter in Home Assistant workshop announcement
The workshop instructions can be found here.
Home Assistant SkyConnect interest form
Matter is a new smart home standard
We’ve been hard at work on Matter support for Home Assistant. The Home Assistant Yellow hub will come with a radio that supports Thread, required to talk to low power Matter devices. We also have some tricks up our sleeves for devices used to run Home Assistant without such a radio, like Raspberry Pi’s. We want to show what we’re up to and allow you to test it out.
On June 15 @ 12:00 PDT / 21:00 CET we will be hosting our free Matter in Home Assistant workshop.
The workshop will be held on YouTube. Go to the listing to set a reminder to be notified when we start.
The workshop will contain two parts. In the first part we will talk about what Matter is and how it will work in Home Assistant. In the second part we will walk you through how to add experimental Matter support to your Home Assistant installation and integrate your first Wi-Fi based Matter device.
The workshop will be free but you will need a couple of things if you want to be able to follow along with the second part:
- Home Assistant OS 8.0 or newer, 64-bit version only (x86-64 or aarch64). Matter relies on an add-on and Bluetooth.
Home Assistant Community Store
installed - Espressif ESP32-C3-DevKitM-1 ($9 @ Mouser
, €17 @ Conrad ) or M5Stamp C3 ($6 @ M5Stack ) - Bluetooth. If you use a Raspberry Pi to run Home Assistant you’re set. If you have a Home Assistant Blue or another device without Bluetooth, get a Bluetooth USB adapter that is supported by Home Assistant OS (like this one
Even if you can’t follow along, it will still be an informative session!
It is possible to get the experimental Matter support working with other Home Assistant installation methods and other dev kits, but we won’t be covering those in our workshop.
