Nabu Casa has acquired ESPHome
Today I’m happy to announce that ESPHome
Otto started ESPHome three years ago to make programming ESP devices as easy as possible. With ESPHome, users write simple YAML files in which you describe what components are attached to what pins of the ESP device. ESPHome will then make this available in Home Assistant. No extra work necessary. Super simple.
Example ESPHome configuration
The following ESPHome YAML example will program your ESP device. When you plug it in, it will make the light on pin 16 available in Home Assistant.
Otto’s vision was right and ESPHome has become the easiest way for people to integrate ESP devices in Home Assistant. For example, the tag reader is based on ESPHome, and many other projects are too.
As the project grew, so did Otto’s obligations in his personal life until they could no longer be combined. With the acquisition of ESPHome, Nabu Casa now owns the copyright of Otto’s code and the ESPHome organizations on GitHub, Docker, etc. Otto has shut down his Patreon account. Otto will step back from being part of the project management side of things. The project will continue as an open source project with the current ESPHome development team, @jesserockz
We are going to bring our experience gained from the Home Assistant project and apply it to ESPHome, like focus on community and ease of use. If you have any ideas, make sure to share them in the ESPHome discord
Update: I’ve joined the Home Assistant podcast to discuss the acquisition. Episode 83 is worth a listen.
About Nabu Casa
Nabu Casa was founded by the founders of Home Assistant. It exists to make the privacy-centered smart home accessible to everyone. Nabu Casa has no investors and is solely funded by users via Home Assistant Cloud subscriptions. With Home Assistant, Nabu Casa already works on making sure the brains of your home are the best it can be. And with ESPHome they will help you make sure that other devices are too.
