Community Highlights: 11th edition
The 11th edition of the Home Assistant Community Highlights! Some interesting things popped up around our community, we thought was worth sharing.
From now on we will also highlight a cool blueprint that we encountered on the Blueprint exchange. Do you want to share something for the next edition? Information on how to share.
./Klaas
Blueprint of the week
Do you have an IP camera in Home Assistant instance and do you no longer want to miss who is at the door? Then you could try the camera snapshot Blueprint from vorion. You can also indicate to which device you would like to receive a notification with a photo. Try it out!
Solar weather station in birdhouse
Spring is approaching, so it’s a good time to start building a birdhouse 🐦, so why not immediately turn it into a weather station? With the manual from Martin, you can make your own weather (birdhouse) station that works with ESPHome.
Outdoor pathway light
Do you have a garden and do you want to create lighting along the paths? Maybe the garden lighting tutorial from KidA001 will give you some inspiration to get started with this.
PoE powered stack light
Looking for a creative way to display the status of your Home Assistant instance? For example: there is a new Core update, too much RAM is being used or your instance is no longer online? Plenty of options to bind to each color segment.
So let yourself be inspired with the PoE stack light from Karl and start building.
Got a tip for the next edition?
Have you seen (or made) something awesome, interesting, unique, amazing, inspirational, unusual or funny, using Home Assistant?
Click here to send us your Community Highlight suggestion.
Also, don’t forget to share your creations with us via Social Media:
See you next edition!
