hass-cli 0.5: Area, Device Registry and event CLI
Comments
With Home Assistant 0.87 out we got Areas and Device Registry UI thus it is time to do a release of hass-cli that allows you to operate on these in a terminal.
This release adds the following features:
  • Area list, create, delete, and rename
  • Device list and assign
  • Event watch
To get it run:
$ pip3 install homeassistant-cli
And once you have configured some of the new things you can like:
Create an area:
$ hass-cli area create Attic
-  id: 1
   type: result
   success: true
   result:
      area_id: 83977bdb16524579a856560925a791a7
List all your areas:
$ hass-cli area list
ID                                NAME
295afc88012341ecb897cd12d3fbc6b4  Bathroom
9e08d89203804d5db995c3d0d5dbd91b  Winter Garden
8816ee92b7b84f54bbb30a68b877e739  Office
e6ebd3e6f6e04b63a0e4a109b4748584  Kitchen
f7f5412a9f47436da669a537e0c0c10f  Livingroom
bc98c209249f452f8d074e8384780e15  Hallway
83977bdb16524579a856560925a791a7  Attic
List devices matching a pattern:
$ hass-cli device list "Kitchen.*Light*"
ID                                NAME                      MODEL                    MANUFACTURER    AREA
f9cad07069c74d519fbe84811c91f1fb  Kitchen Light 2           LCT003                   Philips         e6ebd3e6f6e04b63a0e4a109b4748584
d02ec64623ae4407a80b903cbc061511  Kitchen Light 3           LCT003                   Philips         e6ebd3e6f6e04b63a0e4a109b4748584
820c9e511fce42ea92b228c18710aa56  Kitchen Light 1           LCT003                   Philips         e6ebd3e6f6e04b63a0e4a109b4748584
417dd42c0c764765aa29580d77b8b7ad  Kitchen Light 5           LCT003                   Philips         e6ebd3e6f6e04b63a0e4a109b4748584
Like with entity list you can filter and pipe results to get interesting things.
How about a inventory count?
$ hass-cli --no-headers --columns manufacturer,model device list | sort | uniq -c | sort -nr
10 IKEA of Sweden      TRADFRI bulb GU10 WS 400lm
 8 Philips             SML001
 7 LUMI                lumi.sensor_magnet.aq2
 6 Sonos               Play:1
 6 Philips             LTW012
 6 Philips             LCT003
 6 Philips             Hue color spot
 6 Philips             Hue ambiance candle
 5 Philips             LWG001
 5 Philips             LCT012
 5 Philips             Hue color candle
 5 IKEA of Sweden      TRADFRI bulb E14 W op/ch 400lm
 4 Sonos               One
 4 Philips             RWL021
 4 Philips             Hue color lamp
 4 IKEA of Sweden      TRADFRI remote control
 3 Philips             Hue lightstrip plus
 3 OSRAM               Color temperature light
 3 LUMI                lumi.vibration.aq1
 3 IKEA of Sweden      TRADFRI transformer 30W
And then my favorite feature, assign of area to a device:
$ hass-cli device assign Kitchen "Kitchen Light 2"
or even more powerful, bulk-assign to any entity matching a certain pattern:
$ hass-cli device assign --match "Kitchen" Kitchen
  Successfully assigned 'Kitchen' to 'Kitchen'
  Successfully assigned 'Kitchen' to 'Kitchen table left'
  Successfully assigned 'Kitchen' to 'Kitchen table right'
  Successfully assigned 'Kitchen' to 'Kitchen left middle at window'
  Successfully assigned 'Kitchen' to 'Kitchen front right at fridge'
  Successfully assigned 'Kitchen' to 'Kitchen left back at hub'
  Successfully assigned 'Kitchen' to 'Kitchen left back at bar'
  Successfully assigned 'Kitchen' to 'Kitchen right back at sink'
  Successfully assigned 'Kitchen' to 'Kitchen right middle at oven'
  Successfully assigned 'Kitchen' to 'Kitchen Light 2'
  Successfully assigned 'Kitchen' to 'Kitchen Light 3'
And finally as a little bonus feature you can now watch the event bus from the CLI:
All events:
$ hass-cli event watch
or specific events:
$ hass-cli event watch call_service
At the moment the output is raw JSON, that will improve in a future release.
The full change list including bugfixes from community is as follows:
What’s Changed
New features:
  • Device, Area and event support 237ade8 @maxandersen
  • add minimal dockerfile 2b00bd7 Ben Lebherz
Bug fixes:
  • fix(entity): honor –columns in entity get 67397a1 @maxandersen
  • Fix result reporting from service calls 14fc952 @maxandersen
  • Remove pyaml and move to ruamel only for yaml df9f8c2 @maxandersen
Minor fixes:
  • fix: release 0.5.0 version 200a099 @maxandersen
  • fix: be pep440 complant 98320f8 @maxandersen
  • fix: fix lint errors eca26fa @maxandersen
  • fix: fix lint errors ffd2369 @maxandersen
  • enable deploy of git timestamped build 4b27a65 @maxandersen
  • Merge branch ‘master’ into dev caaf7b1 @maxandersen
  • add docker reference d3b64e8 @maxandersen
  • docs: add docs for area, device and event watch ee4f74a @maxandersen
  • Make dockerfile build from source + entrypoint b7f8764 @maxandersen
  • Fix lint issue 8bb0c9e @fabaff
  • Fix lint issues 58fdc83 @fabaff
  • fix bad typing 499b544 @maxandersen
  • fix editor formatting 86d9bf8 @maxandersen
  • Fix version 3765a03 @maxandersen
  • Fix version marker edbe4bf @maxandersen
Have fun!
Max Rydahl Andersen
