IP Cameras, Arduinos, Kodi and Efergy Energy Monitors now supported
Another month has passed and some great new features have landed in Home Assistant. This month release has been made possible by balloob
This release includes some architectural changes by me. The first is that the frontend is now based on a NuclearJS
IP Camera Support James has worked very hard to add support for IP cameras to Home Assistant which is included in this release. The initial release focusses on providing generic IP camera support. This means that any webcam that can exposes a JPEG image via a URL can be integrated.
Home Assistant will route the requests to your camera via the server allowing you to expose IP camera’s inside your network via the Home Assistant app.
Arduino
Fabian has contributed support for interfacing with Arduinos. This makes it possible to connect your Arduino via USB and expose pins as sensor data and write to pins via switches. Have a look at the docs for an extensive guide to get started.
Kodi (XBMC)
Ettisan has contributed a Kodi (XBMC) platform for the media player component. This allows you to track all the media that you are playing and allow you to control it.
TP-Link
Michael has added TP-Link support to the device tracker. This allows you to now detect presence if you have a TP-Link router.
Efergy energy monitor
Miniconfig has contributed support for the Efergy energy meters
Forecast.io
Fabian has added support for Forecast.ioconfiguration.yaml
file:
