Digital Ocean
The Digital Ocean integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to access the information about your Digital Ocean droplets from Home Assistant.
Setup
Obtain your API key from your Digital Ocean dashboard.
To integrate your Digital Ocean droplets with Home Assistant, add the following section to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
digital_ocean:
  access_token: YOUR_API_KEY
access_token string Required
Your Digital Ocean API access token.
Binary sensor
The digital_ocean binary sensor platform allows you to monitor your Digital Ocean droplets.
To use your Digital Ocean droplets, you first have to set up your Digital Ocean hub and then add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file:
binary_sensor:
  - platform: digital_ocean
    droplets:
      - 'fedora-512mb-nyc3-01'
      - 'coreos-512mb-nyc3-01'
droplets list Required
List of droplets you want to monitor.
Switch
The digital_ocean switch platform allows you to control (start/stop) your Digital Ocean droplets.
switch:
    droplets:
List of droplets you want to control.
