Input button
The Input button helper integration allows you to define buttons that can be pressed via the user interface, and can be used to trigger things, like an automation.
The preferred way to configure button helpers is via the user interface. To add one, go to Settings -> Devices & Services -> Helpers and click the add button; next choose the Button option.
To be able to add Helpers via the user interface you should have default_config: in your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more], it should already be there by default unless you removed it. If you removed default_config: from your configuration, you must add input_button: to your configuration.yaml first, then you can use the UI.
Input buttons can also be configured via configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more]:
input_button:
  ring_bell:
    icon: mdi:bell
input_button map Required
Alias for the input. Multiple entries are allowed.
name string (Optional)
Friendly name of the input.
icon icon (Optional)
Icon to display in front of the input element in the frontend.
Automation examples
The input_button entity is stateless, as in, it cannot have a state like the on or off state that, for example, a normal switch entity has.
Every input button entity does keep track of the timestamp of when the last time the input button entity has been pressed in the Home Assistant UI or pressed via a service call.
Because the state of a input button entity in Home Assistant is a timestamp, it means we can use it in our automations. For example:
trigger:
  - platform: state
    entity_id: input_button.my_button
action:
  - service: notify.frenck
      message: "My button has been pressed!"
Services
The input button entities exposes a single service: input_button.press
This service can be called to trigger a button press for that entity.
- service: input_button.press
