FAA Delays
The FAA Delays integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] collects and displays information about delays at US Airports based on the FAA’s National Airspace System Status.
Data measured includes:
  • Ground Delays
  • Ground Stops
  • Arrival/Departure Delays
  • Closures
To add the FAA Delays integration to your Home Assistant instance, use this My button:
Supported airports
The airport entered must be a valid IATA airport code for an airport in the US. You can find this by looking up the FAA Identifier at Airnav.
Additional delay information
Each airport added will expose 5 binary sensors, one for each type of delay. Within each sensor there is additional information listed as attributes, which depends on the type of delay it is. Each delay type has the attributes listed below:
  • Ground Delay
    • Average Delay Time
    • Delay reason
  • Ground Stop
    • Expected End Time for stop
    • Delay reason
    • Minimum delay time
    • Maximum delay time
    • Delay trend (increasing/decreasing)
    • Delay reason
  • Closure
    • Start of closure (begin)
    • End of closure (end)
