Cisco IOS
This is a presence detection scanner for Cisco IOS devices.
This device tracker needs SSH to be enabled on the router.
Before using this scanner it is recommended that you lower the ARP cache timeout on your router, as Cisco IOS normally comes with a 4 hour default ARP cache timeout.
For example, the following commands will lower the timeout to 2 minutes on Vlan1:
# 1. use this command to see what Vlan your devices are on
show ip arp
# 2. Go into configure mode
conf t
# 3. Use the Vlan name as you see it from step 1 above
interface Vlan1
# 4. Set a new arp cache timeout
arp timeout 120
# 5. Exit
# Press <ctrl+c> to exit configure mode
# 6. Don't forget to save the new config, so that it will survive a reboot
copy running-config startup-config
If you have a very large number of devices on your VLan (+1000), then you may want to adjust the ARP cache timeout to suit your needs. See this discussion to learn more.
To use this device tracker in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
device_tracker:
  - platform: cisco_ios
    host: ROUTER_IP_ADDRESS
    username: YOUR_ADMIN_USERNAME
    password: YOUR_ADMIN_PASSWORD
host string Required
The IP address of your router, e.g., 192.168.1.1.
username string Required
The username of a user with administrative privileges.
password string Required
The password for your given admin account.
