Troubleshooting Automations
You can verify that your automation rules are being initialized correctly by watching both the realtime logs (homeassistant.log in the configuration directory) and also the Logbook. The realtime logs will show the rules being initialized (once for each trigger), example:
INFO [homeassistant.components.automation] Initialized rule Rainy Day
INFO [homeassistant.components.automation] Initialized rule Rain is over
The Logbook component will show a line entry when an automation is triggered. You can look at the previous entry to determine which trigger in the rule triggered the event.
Logbook example
