Yale Access Bluetooth
Integrates Yale Access Bluetooth devices into Home Assistant.
To add the Yale Access Bluetooth integration to your Home Assistant instance, use this My button:
The Yale Access Bluetooth integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will automatically discover devices once the Bluetooth integration is enabled and functional.
Devices must have a Yale Access module installed to function with this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] if one is not already built-in.
Supported devices
  • YRD216 (Yale Assure Lock Keypad with Physical Key)
  • YRL216 (Yale Assure Door Lever Lock with Push Button Keypad)
  • YRD226 (Yale Assure Lock Touchscreen Deadbolt with Physical Key)
  • YRL226 (Yale Assure Door Lever Lock Keypad)
  • YRD256 (Yale Assure Lock Keypad)
  • YRD420 (Yale Assure Lock 2)
  • YRD450 (Yale Assure Lock 2 Key Free)
  • YUR/SSDL/1/SIL (Yale Unity Screen Door Lock - Australia)
  • YUR/DEL/1/SIL (Yale Unity Entrance Lock - Australia)
  • IES-D210W-G0 (Yale Smart Safe)
  • YRSM-1 (Yale Smart Safe)
  • ASL-05 (August WiFi Smart Lock - Gen 4)
  • ASL-03 (August Smart Lock Pro - Gen 3)
  • ASL-02 (August Smart Lock Pro - Gen 2)
Limited support devices
These devices do not send updates, but can be locked and unlocked.
  • MD-04I (Yale Conexis L1, Yale Conexis L2)
  • YRCB-490 (Yale Smart Cabinet Lock)
Lock operation requires setting up an encrypted connection highly sensitive to latency. It is recommended to use a High-Performance Bluetooth adapter or ESPHome Bluetooth proxy for stable operation.
Push updates
Some locks only send push updates when they have an active HomeKit pairing. If your lock is not sending push updates, ensure it’s paired with a HomeKit using an iOS device or the HomeKit controller integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more]. The lock cannot be paired via HomeKit Controller and the Yale Access Bluetooth integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] on the same Home Assistant instance as they will both try to access the lock simultaneously and fail.
One easy way to fix this is to create a new/second home in the Apple Home app and add the lock to that new home. Push updates should occur as intended after the lock is added.
Alternatively, call the homeassistant.update_entity service to force the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] to update the lock state, or enable the always connected option.
Options
Options for Yale Access Bluetooth can be set via the user interface, by taking the following steps:
  • If multiple instances of Yale Access Bluetooth are configured, choose the instance you want to configure.
  • Select the integration, then select Configure.
If the lock does not support push updates via advertisements or you want lock operation to be more responsive, you can enable always connected mode. Always connected will cause the lock to stay connected to Home Assistant via Bluetooth, which will use more battery.
Door sensors
The lock must be calibrated in the Yale Access App for the door sensors to function correctly. If the door sensor has an unknown state or is not updating, try recalibrating the lock in the app.
Obtaining the offline key
The offline key and slot number are required to operate the lock. These credentials can be found in multiple places depending on the lock brand and model.
Yale Access, Yale Home, or August Cloud
The August integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] can automatically provision the offline key if the configured account has the key loaded. You may need to create or use a non-primary existing account with owner-level access to the lock, as not all accounts will have the key loaded. If the lock was not discovered by Home Assistant when the cloud integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] was loaded, reload the cloud integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] once the lock has been discovered.
If the offline key can automatically be provisioned, you will not be asked to enter it and the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] should be automatically added, configured and running.
Most Yale branded locks can use the August cloud to obtain the keys. Accessing the August cloud to receive the key may not work unless the lock was purchased in a market that sells under both brands.
iOS - Yale Access App or August App
The iOS app will only save the offline key to your device’s filesystem if Auto-Unlock has been enabled and used at least once. Auto-Unlock can be disabled once the key has been loaded.
  • Using iMazing or iPhone Backup Extractor, find the backup files for the Yale Access app.
  • Look in the Library/Preferences .plist files for the Yale Access app and find the one with the value of key and slot using Xcode or any binary plist viewer.
Android - Yale Access App or August App
The Android app will only save the offline key to your device’s filesystem if Auto-Unlock has been enabled and used at least once. Auto-Unlock can be disabled once the key has been loaded.
Root access is required to read the key and slot stored in /data/data/com.august.luna/shared_prefs/PeripheralInfoCache.xml
Android - Yale Home
Root access is required to copy the ModelDatabase.sql from /data/data/com.assaabloy.yale/databases. Once copied, you can use DB Broser for SQLite to open the ModelDatabase.sql, navigate to the table LockData and find the column offlineKeys.There, you will find a JSON that includes the key and slot properties.
Lock frequently requires re-authentication
If you use the key from an iOS or Android device that you also frequently use to operate the lock, you may find that the key is rotated, and the integration can no longer authenticate. If you are using the August integration to keep the key up to date, it may need to be reloaded to update the key.
To avoid the problem, create a second owner account in the August app, log in to it once on your iOS or Android device, operate the locks, log out of the account, remove the August integration, and set up the August integration with the secondary owner account. This method avoids the problem because there is no longer an iOS or Android device logged into the secondary owner account that can rotate the key unexpectedly.
