Xiaomi Miio
The Xiaomi Miio integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] supports the following devices:
- Xiaomi Gateway
- Xiaomi device tracker (Xiaomi Mi WiFi Repeater 2)
- Xiaomi Air Purifier, Air Humidifier and Standing Fan
- Xiaomi Air Quality Monitor
- Xiaomi IR Remote
- Xiaomi Mi Robot Vacuum
- Xiaomi Philips Light
- Xiaomi Smart WiFi Socket and Smart Power Strip
Most Xiaomi Miio devices support configuration using the Home Assistant UI, except for the Xiaomi device tracker and Xiaomi IR Remote. Please read the linked sections for those devices for more information.
Devices need to be set up using the Mi Home app and not vendor-specific apps (e.g. Roborock).
For more complex network setups (e.g. VLANs), reference the following documentation
To add the Xiaomi Miio integration to your Home Assistant instance, use this My button:
Xiaomi Miio can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Xiaomi Miio.
It is recommend to supply your Xiaomi cloud credentials during configuration
to automatically connect to your devices. You need to specify the cloud server
you used in the Xiaomi Home App (where you initially setup the device). There are
6 servers: cn
, de
, i2
, ru
, sg
and us
; please see
this page
The most common problems are:
- Xiaomi Miio devices do not communicate across subnets/VLANs due to the source address of the UDP packet not belonging to the subnet of the device itself, more information and solutions
. - Roborock vacuums need to be connected to the Xiaomi Home app, not the Roborock app, more information
. - Blocking the network access to the device is known to cause intermittent connection issues due to the device’s internal software hanging and a watchdog restarting the internal software, more information
Xiaomi Gateway
The xiaomi_miio
gateway integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control the gateway and its connected subdevices.
Supported Xiaomi gateway models
The following list shows the Gateway name, the model number, the Zigbee ID, and whether the model is supported or not in Home Assistant.
Chinese version
- Model: DGNWG02LM
- Zigbee ID: lumi.gateway.v3
- Supported: Yes
European version
- Model: ZHWG11LM-763 / DGNWQ05LM
- Zigbee ID: lumi.gateway.mieu01
- Supported: Yes (cloud credentials needed)
Aqara hub
- Model: ZHWG11LM
- Zigbee ID: lumi.gateway.aqhm01
- Supported: Yes
Mijia Zigbee 3.0
- Model: ZNDMWG03LM
- Zigbee ID: lumi.gateway.mgl03
- Supported: Yes
Aqara AC Companion
- Model: KTBL01LM
- Zigbee ID: lumi.acpartner.v1
- Supported: Untested
Mi AC Companion
- Model: KTBL02LM
- Zigbee ID: lumi.acpartner.v2
Aqara AC Companion
- Model: KTBL11LM
- Zigbee ID: lumi.acpartner.v3
- Supported: Yes
Some gateways (lumi.gateway.mieu01) do not support getting the connected subdevices locally. For those gateways, cloud credentials can be specified during the config flow and the “Use cloud to get connected subdevices” can be enabled in the options flow (after setting up the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more], click Configuration in the sidebar, then click Integrations and then click Options on the already set up Xiaomi Miio Gateway integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more]). The connected subdevices will then be retrieved from the Xiaomi Miio cloud (internet), control and status updates of those subdevices will then further take place over local network connection. A re-authentication flow may be triggered when no cloud credentials are provided yet and are needed for that particular gateway model.
Gateway features
- Gateway alarm control (Turn on/off; see status
armed_away
,disarmed
,arming
) - Gateway light control (Turn on/off; change brightness; change color; see status)
- Gateway illuminance sensor readout (illuminance value in lux)
Not yet implemented features (but possible):
- Gateway internet radio (only chinese stations)
- Gateway ringtones/sounds
Supported subdevices
These subdevices are fully implemented in HomeAssistant:
Weather sensor (WSDCGQ01LM)
- Zigbee ID:
lumi.sensor_ht
- Features: readout
temperature
andhumidity
- Zigbee ID:
Weather sensor (WSDCGQ11LM)
- Zigbee ID:
lumi.weather.v1
- Features: readout
temperature
,humidity
andpressure
- Zigbee ID:
Wall switch single (QBKG11LM)
- Zigbee ID:
lumi.ctrl_ln1
- Features: load_power, status, turn_on, turn_off, toggle
- Zigbee ID:
- Zigbee ID:
lumi.ctrl_ln1.aq1
- Zigbee ID:
Wall switch no neutral (QBKG04LM)
- Zigbee ID:
lumi.ctrl_neutral1.v1
- Features: status, turn_on, turn_off, toggle
- Zigbee ID:
Wall switch double (QBKG12LM)
- Zigbee ID:
lumi.ctrl_ln2
- Zigbee ID:
- Zigbee ID:
lumi.ctrl_ln2.aq1
- Zigbee ID:
Wall switch double no neutral (QBKG03LM)
- Zigbee ID:
lumi.ctrl_neutral2
- Zigbee ID:
D1 wall switch triple (QBKG26LM)
- Zigbee ID:
lumi.switch.n3acn3
- Zigbee ID:
D1 wall switch triple no neutral (QBKG25LM)
- Zigbee ID:
lumi.switch.l3acn3
- Zigbee ID:
Wall outlet (QBCZ11LM)
- Zigbee ID:
lumi.ctrl_86plug.v1
- Zigbee ID:
- Zigbee ID:
lumi.ctrl_86plug.aq1
- Zigbee ID:
Plug (ZNCZ02LM)
- Zigbee ID:
lumi.plug
- Zigbee ID:
Relay (LLKZMK11LM)
- Zigbee ID:
lumi.relay.c2acn01
- Zigbee ID:
Smart bulb E27 (ZNLDP12LM)
- Zigbee ID:
lumi.light.aqcn02
- Features: on/off, brightness, color temperature
- Zigbee ID:
IKEA smart bulb E27 white (LED1545G12)
- Zigbee ID:
ikea.light.led1545g12
- Zigbee ID:
IKEA smart bulb E27 white (LED1546G12)
- Zigbee ID:
ikea.light.led1546g12
- Zigbee ID:
IKEA smart bulb E12 white (LED1536G5)
- Zigbee ID:
ikea.light.led1536g5
- Zigbee ID:
IKEA smart bulb GU10 white (LED1537R6)
- Zigbee ID:
ikea.light.led1537r6
- Zigbee ID:
IKEA smart bulb E27 white (LED1623G12)
- Zigbee ID:
ikea.light.led1623g12
- Zigbee ID:
IKEA smart bulb GU10 white (LED1650R5)
- Zigbee ID:
ikea.light.led1650r5
- Zigbee ID:
IKEA smart bulb E12 white (LED1649C5)
- Zigbee ID:
ikea.light.led1649c5
- Zigbee ID:
Recognized subdevices (not yet implemented)
These subdevices are recognized by the python-miio code but are still being worked on (not yet implemented).
The list shows the device name, the model number, and the Zigbee ID.
Button (WXKG01LM):
lumi.sensor_switch
Button (WXKG11LM 2015):
lumi.sensor_switch.aq2
Button (WXKG12LM):
lumi.sensor_switch.aq3
Button (WXKG11LM 2018):
lumi.remote.b1acn01
Cube (MFKZQ01LM):
lumi.sensor_cube.v1
Cube (MFKZQ01LM):
lumi.sensor_cube.aqgl01
Motion sensor (RTCGQ01LM):
lumi.sensor_motion
Motion sensor (RTCGQ11LM):
lumi.sensor_motion.aq2
Door sensor (MCCGQ01LM):
lumi.sensor_magnet
Door sensor (MCCGQ11LM):
lumi.sensor_magnet.aq2
Vibration sensor (DJT11LM):
lumi.vibration.aq1
Honeywell smoke detector (JTYJ-GD-01LM/BW):
lumi.sensor_smoke
Honeywell natural gas detector (JTQJ-BF-01LM/BW):
lumi.sensor_natgas
Water leak sensor (SJCGQ11LM):
lumi.sensor_wleak.aq1
Remote switch single (WXKG03LM 2016):
lumi.sensor_86sw1.v1
Remote switch single (WXKG03LM 2018):
lumi.remote.b186acn01
D1 remote switch single (WXKG06LM):
lumi.remote.b186acn02
Remote switch double (WXKG02LM 2016):
lumi.sensor_86sw2.v1
Remote switch double (WXKG02LM 2018):
lumi.remote.b286acn01
D1 remote switch double (WXKG07LM):
lumi.remote.b286acn02
Curtain (ZNCLDJ11LM):
lumi.curtain
Curtain (ZNGZDJ11LM):
lumi.curtain.aq2
Curtain B1 (ZNCLDJ12LM):
lumi.curtain.hagl04
Door lock S1 (ZNMS11LM):
lumi.lock.aq1
Door lock S2 (ZNMS12LM):
lumi.lock.acn02
Door lock S2 pro (ZNMS13LM):
lumi.lock.acn03
Vima cylinder lock (A6121):
lumi.lock.v1
Thermostat S2 (KTWKQ03ES):
lumi.airrtc.tcpecn02
The xiaomi_miio
device tracker platform is observing your Xiaomi Mi WiFi Repeater 2 and reporting all associated WiFi clients.
Please follow the instructions on Retrieving the Access Token to get the API token.
To add a Xiaomi Mi WiFi Repeater device tracker to your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
device_tracker:
- platform: xiaomi_miio
host: 192.168.130.73
token: YOUR_TOKEN
The Air Purifiers, Air Humidifiers and Standing Fans use multiple platforms to allow you to set the control modes and settings of the device.
Supported devices:
The list includes device name, model number (if available), and model.
Air Purifier:
zhimi.airpurifier.v1
Air Purifier 2 (FJY4006CN):
zhimi.airpurifier.v2
Air Purifier V3:
zhimi.airpurifier.v3
Air Purifier V5:
zhimi.airpurifier.v5
Air Purifier Pro:
zhimi.airpurifier.v6
Air Purifier Pro V7:
zhimi.airpurifier.v7
Air Purifier 2 (mini):
zhimi.airpurifier.m1
Air Purifier (mini):
zhimi.airpurifier.m2
Air Purifier MA1:
zhimi.airpurifier.ma1
Air Purifier MA2:
zhimi.airpurifier.ma2
Air Purifier 2S:
zhimi.airpurifier.mc1
Air Purifier Super:
zhimi.airpurifier.sa1
Air Purifier Super 2:
zhimi.airpurifier.sa2
Air Purifier 3 (2019) (AC-M6-SC):
zhimi.airpurifier.ma4
Air Purifier 3H (2019):
zhimi.airpurifier.mb3
Air Purifier Pro H:
zhimi.airpurifier.va1
Air Purifier Pro H EU:
zhimi.airpurifier.vb2
Air Purifier 3C:
zhimi.airpurifier.mb4
Air Purifier 3C:
zhimi.airp.mb4a
Air Purifier ZA1:
zhimi.airpurifier.za1
Air Purifier 4 (AC-M16-SC):
zhimi.airp.mb5
Air Purifier 4 PRO (AC-M15-SC):
zhimi.airp.vb4
Air Fresh A1 (MJXFJ-150-A1):
dmaker.airfresh.a1
Air Fresh VA2:
zhimi.airfresh.va2
Air Fresh VA4:
zhimi.airfresh.va4
Air Fresh T2017 (MJXFJ-300-G1):
dmaker.airfresh.t2017
Air Humidifier:
zhimi.humidifier.v1
Air Humidifier CA1:
zhimi.humidifier.ca1
Air Humidifier CA4:
zhimi.humidifier.ca4
Air Humidifier CB1:
zhimi.humidifier.cb1
Air Humidifier JSQ:
deerma.humidifier.jsq
Air Humidifier JSQ1:
deerma.humidifier.jsq1
Air Humidifier MJJSQ:
deerma.humidifier.mjjsq
Standing Fan 1X:
dmaker.fan.p5
Inverter Pedestal Fan:
zhimi.fan.za1
Standing Fan 2:
zhimi.fan.za3
Standing Fan 2S:
zhimi.fan.za4
Standing Fan:
zhimi.fan.sa1
DC Pedestal Fan:
zhimi.fan.v2
DC Pedestal Fan:
zhimi.fan.v3
Standing Fan 1C:
dmaker.fan.1c
Tower Fan:
dmaker.fan.p9
Standing Fan 2:
dmaker.fan.p10
Standing Fan Pro:
dmaker.fan.p11
Standing Fan 3:
zhimi.fan.za5
Power (on, off)
Operation modes (Auto, Silent, Favorite, Idle)
Attributes (fan platform)
model
mode
sleep_time
sleep_mode_learn_count
extra_features
turbo_mode_supported
use_time
button_pressed
sleep_mode
Number entities
Number | Description |
Favorite Level | Set the favorite level |
Sensor entities
Filter Lifetime Remaining: The remaining life of the filter. Enabled by default.
Filter Use: Filter usage time in hours. Enabled by default.
Humidity: The current humidity measured. Enabled by default.
Motor Speed: The current motor speed measured in rpm. Enabled by default.
PM2.5: The current particulate matter 2.5 measured. Enabled by default.
Purify Volume: The volume of purified air in cubic meter. Disabled by default.
Temperature: The current temperature measured. Enabled by default.
Use Time: The accumulative number of seconds the device has been in use. Disabled by default.
Switch entities
Switch | Description |
Buzzer | Turn on/off the buzzer |
Child Lock | Turn on/off the child lock |
Learn Mode | Turn on/off the learn mode |
LED | Turn on/off the LED |
Air Purifier Pro (zhimi.airpurifier.v6)
- Power (on, off)
- Operation modes (Auto, Silent, Favorite)
- Attributes (fan platform)
sleep_time
extra_features
auto_detect
use_time
button_pressed
- Number entities
Volume | Set the volume |
Sensor entities
- Filter Life Remaining: The remaining lifetime of the filter. Enabled by default.
- Filter Use: Filter usage time in hours. Enabled by default.
- Humidity: The current humidity measured. Enabled by default.
- Illuminance: The current illuminance measured. Enabled by default.
- Motor Speed: The current motor speed measured in rpm. Enabled by default.
- PM2.5: The current particulate matter 2.5 measured. Enabled by default.
- Purify Volume: The volume of purified air in cubic meter. Disabled by default.
- Second Motor Speed: The current second motor speed measured in rpm. Enabled by default.
- Temperature: The current temperature measured. Enabled by default.
- Use Time: The accumulative number of seconds the device has been in use. Disabled by default.
Switch entities
Air Purifier Pro V7 (zhimi.airpurifier.v7)
- Power (on, off)
extra_features
button_pressed
- Number entities
Sensor entities
- Filter Lifetime Remaining: The remaining lifetime of the filter. Enabled by default.
Switch entities
Air Purifier MA2 (zhimi.airpurifier.ma2)
- Power (on, off)
extra_features
button_pressed
preset_modes
preset_mode
sleep_time
use_time
sleep_mode
friendly_name
supported_features
Sensor entities
- Illuminance: The current illuminance measured on top of the device (0-200 lux). Enabled by default.
Switch entities
Air Purifier 2S (zhimi.airpurifier.mc1)
- Power (on, off)
extra_features
button_pressed
- Number entities
Sensor entities
Switch entities
Air Purifier 3/3H (2019) (zhimi.airpurifier.ma4, zhimi.airpurifier.mb3)
This model uses newer MiOT communication protocol.
- Power (on, off)
- Operation modes (Auto, Silent, Favorite, Fan)
use_time
- Number entities
Fan Level | Set the fan level |
- Select entities
Select | Description |
LED Brightness | Controls the brightness of the LEDs (bright, dim, off) |
Sensor entities
Switch entities
Air Purifier Pro H, Pro H EU (zhimi.airpurifier.va1, zhimi.airpurifier.vb2)
- Power (on, off)
use_time
- Number entities
- Select entities
Sensor entities
Switch entities
Air Purifier 3C (zhimi.airpurifier.mb4, zhimi.airp.mb4a)
- Power (on, off)
- Number entities
Favorite Motor Speed | Set the favorite motor speed |
LED Brightness | Set the LED brightness |
Sensor entities
Switch entities
Air Purifier ZA1 (zhimi.airpurifier.za1)
- Power (on, off)
- Number entities
Sensor entities
- TVOC: The current concentration of Total Organic Volatile Components. Enabled by default.
Switch entities
- Select entities
LED Brightness | Controls the brightness of the Display (bright, dim, off) |
Air Purifier V3 (zhimi.airpurifier.v3)
Power (on, off)
Operation modes (Auto, Silent, Favorite, Idle, Medium, High, Strong)
sleep_time
extra_features
use_time
button_pressed
Sensor entities
Switch entities
Air Purifier 4/4 PRO (zhimi.airp.mb5, zhimi.airp.vb4)
These models use newer MiOT communication protocol.
- Power (on, off)
- Number entities
- Select entities
Sensor entities
- Filter Lifetime Remaining: The remaining lifetime of the filter in %. Enabled by default.
- Filter Time Left: The remaining lifetime of the filter in days. Enabled by default.
- PM10: The current particulate matter 10 measured (4 PRO only). Enabled by default.
Switch entities
Ionizer | Turn on/off the negative ion generator |
Air Fresh A1 (dmaker.airfresh.a1)
- Power (on, off)
- Operation modes (Auto, Sleep, Favorite)
- Binary sensor entities
Binary sensor | Description |
Auxiliary Heat Status | Indicates if the heater is actually on |
- Button entities
Button | Description |
Reset Dust Filter | Resets filter lifetimetime and usage of the dust filter |
- Sensor entities
Sensor | Description |
Carbon Dioxide | The current carbon dioxide in ppm |
Dust filter lifetime remaining | The remaining lifetime of the filter |
Dust filter lifetime remaining days | The remaining lifetime of the filter in day |
PM2.5 | The current particulate matter 2.5 |
Temperature | The current outside temperature |
Control Speed | The current motor speed in rpm |
Favorite Speed | The favorite motor speed in rpm |
- Switch entities
Buzzer | Turn on/off buzzer
Child Lock | Turn on/off child lock
Display | Turn on/off display
Auxiliary Heat | Turn on/off heater
Air Fresh VA2
Power (on, off)
Operation modes (Auto, Silent, Interval, Low, Middle, Strong)
use_time
extra_features
Sensor entities|
- Carbon Dioxide: The current carbon dioxide measured in ppm. Enabled by default.
Select entities
- Switch entities
LED | Turn on/off led
Air Fresh VA4
- Power (on, off)
- Operation modes (Auto, Silent, Interval, Low, Middle, Strong)
use_time
extra_features
- Sensor entities
Sensor | Description | Enabled by default |
Carbon Dioxide | The current carbon dioxide measured in ppm | True |
Filter Lifetime Remaining | The remaining lifetime of the filter | True |
Filter Use | Filter usage time in hours | True |
Humidity | The current humidity measured | True |
PM2.5 | The current particulate matter 2.5 measured | True |
Temperature | The current temperature measured | True |
Use Time | The accumulative number of seconds the device has been in use | False |
- Select entities
- Switch entities
Air Fresh T2017 (dmaker.airfresh.t2017)
Power (on, off)
- Auxiliary Heat Status: Indicates if the heater is actually on
Button entities
- Reset Dust Filter: Resets filter lifetime and usage of the dust filter
- Reset Upper Filter: Resets filter lifetime and usage of the upper filter
Select entities
- Auxiliary Heat Level: Controls the level of the heater (Low, Medium, High)
- Display Orientation: Controls the orientation of the display (Forward, Left, Right)
Sensor entities
- Carbon Dioxide: The current carbon dioxide in ppm
- Dust filter lifetime remaining: The remaining lifetime of the dust filter
- Dust filter lifetime remaining days: The remaining lifetime of the dust filter in days
- Upper filter lifetime remaining: The remaining lifetime of the upper filter
- Upper filter lifetime remaining days: The remaining lifetime of the upper filter in days
- Temperature: The current outside temperature
- Control Speed: The current motor speed in rpm
- Favorite Speed: The favorite motor speed in rpm
Switch entities
Air Humidifier (zhimi.humidifier.v1)
- On, Off
- Operation modes (Silent, Medium, High, Strong)
- Target humidity (30, 40, 50, 60, 70, 80)
- Attributes (humidifier platform)
Attribute | Description |
available_modes |
A list with the operation modes available |
humidity |
The current target humidity |
max_humidity |
The maximum settable target humidity |
min_humidity |
The minimum settable target humidity |
mode |
The current operation mode selected |
Water Tank | Indicates whether the water tank is connected or not |
- Select entities
Sensor entities
- Water Level: The current water level percentage measured. Enabled by default.
Switch entities
Air Humidifier CA (zhimi.humidifier.ca1)
- On, Off
- Operation modes (Silent, Medium, High, Auto)
available_modes |
humidity |
max_humidity |
min_humidity |
mode |
- Select entities
Sensor entities
Switch entities
Dry Mode | Turn on/off the dry mode |
Air Humidifier CA (zhimi.humidifier.ca4)
- On, Off
- Operation modes (Auto, Low, Medium, High)
- Target humidity (30 - 80)
available_modes |
humidity |
max_humidity |
min_humidity |
mode |
- Number entities
Motor Speed | Set the motor speed |
- Select entities
Sensor entities
- Actual Speed: The current motor speed measured in rpm. Enabled by default.
Switch entities
Clean Mode | Turn on/off the clean mode |
Clean mode and Motor speed can only be set when the device is turned on.
Air Humidifier CB (zhimi.humidifier.cb1)
- On, Off
available_modes |
humidity |
max_humidity |
min_humidity |
mode |
- Select entities
Sensor entities
Switch entities
Air Humidifier JSQ/JSQ1/MJJSQ (deerma.humidifier.jsq, deerma.humidifier.jsq1, deerma.humidifier.mjjsq)
- On, Off
- Operation modes (low, medium, high, humidity)
available_modes |
humidity |
max_humidity |
min_humidity |
mode |
Water Tank Empty | Indicates whether the water tank is empty or not |
Sensor entities|
Switch entities
Standing Fan 1X (dmaker.fan.p5)
- Power (on, off)
- Operation modes (Normal, Nature)
- Oscillation (on, off)
- Number entities
Delay Off Countdown | Set the delay off countdown in minutes |
Oscillation Angle | Set the oscillation angle in degrees |
- Switch entities
Standing Fan (zhimi.fan.za1, zhimi.fan.za3, zhimi.fan.za4, zhimi.fan.sa1)
- Power (on, off)
- Number entities
- Select entities
- Switch entities
DC Pedestal Fan (zhimi.fan.v2, zhimi.fan.v3)
- Power (on, off)
- Number entities
- Select entities
- Sensor entities
Battery | The current battery level in percentage |
- Switch entities
Standing Fan 1C (dmaker.fan.1c)
- Power (on, off)
- Number entities
- Switch entities
Buzzer | Turn on/off the Buzzer |
Child Lock | Turn on/off the Child Lock |
Tower Fan/Standing Fan 2/Standing Fan Pro (dmaker.fan.p9, dmaker.fan.p10, dmaker.fan.p11)
- Power (on, off)
- Number entities
- Switch entities
Standing Fan 3 (zhimi.fan.za5)
- Power (on, off)
Power Supply | Indicates whether the power supply is connected or not |
- Number entities
- Sensor entities
- Switch entities
Ionizer | Turn on/off the Ionizer |
Actions
Action humidifier.set_humidity
Set the target humidity.
entity_id |
no | Only act on a specific Xiaomi miIO humidifier entity. |
humidity |
no | Target humidity |
Action humidifier.set_mode
Set the humidifier operation mode.
entity_id |
mode |
no | The Xiaomi miIO operation mode |
Action fan.set_percentage
Set the fan speed percentage.
entity_id |
no | Only act on a specific Xiaomi miIO fan entity. |
percentage |
no | Fan speed. Percentage speed setting |
Action fan.set_preset_mode
Set the fan operation mode.
entity_id |
preset_mode |
Action xiaomi_miio.fan_reset_filter (Air Purifier 2 only)
Reset the filter lifetime and usage.
entity_id |
Action xiaomi_miio.fan_set_extra_features (Air Purifier only)
Set the extra features.
entity_id |
features |
no | Integer, known values are 0 and 1. |
The xiaomi_miio
Air Quality Monitor is observing your Xiaomi Mi Air Quality Monitor (PM2.5) and reporting the air quality index and other values.
Currently, the supported features are:
- Air Quality Index (AQI)
- Particulate matter 2.5
- Attributes
- power
- charging
- battery
- time_stat
- carbon_dioxide_equivalent
- total_volatile_organic_compounds
- temperature
- humidity
Xiaomi IR Remote
The xiaomi miio
remote platform allows you to send IR commands from your Xiaomi IR Remote (ChuangmiIr).
Setup
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml
Configuring the Platform
To add a Xiaomi IR Remote to your installation, add the following to your configuration.yaml
remote:
host: 192.168.42.42
token: YOUR_TOKEN
A list of commands
A list of commands as raw (learned command) or pronto hex code.
Full Configuration
remote:
host: 192.168.42.42
token: YOUR_TOKEN
slot: 1
timeout: 30
commands:
activate_towel_heater:
command:
- raw:base64:[optional_frequency]
read_bad_poem:
command:
- pronto:pronto_hex:[optional_repeat]
Add command as entity button to a dashboard
type: entity-button
tap_action:
action: call-service
action: remote.send_command
command: activate_towel_heater
entity_id: remote.xiaomi_miio_ir
hold_action:
action: more-info
show_icon: true
show_name: true
entity: remote.xiaomi_miio_ir
icon: "mdi:radiator"
name: Activate Towel Heater
Use named commands to create UI buttons
script:
towel_heater:
sequence:
- action: remote.send_command
entity_id: "remote.bathroom_remote"
command:
- "activate_towel_heater"
please_cover_your_ears:
sequence:
command:
- "read_bad_poem"
Command Types
The Xiaomi IR Remote Platform currently supports two different formats for IR codes.
Raw
A raw command is a command learned from xiaomi_miio.remote_learn_command
A raw command is defined as in the following example:
raw:Z6UFANEAAAAjAQAAAwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQIAE=
with an optional last parameter of frequency:
raw:Z6UFANEAAAAjAQAAAwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQIAE=:38400
Pronto Hex Code
A pronto hex code is a hex code often supplied by the device manufacturer.
A pronto hex code is defined as in the following example:
pronto:0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0623 015B 0057 0016 0E6E
with an optional last parameter of repeats (required by some devices):
pronto:0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0623 015B 0057 0016 0E6E:2
Note there are at least 4 versions of the Xiaomi IR Remote (ChuangmiIr) which can be recognized by their default hostname:
chuangmi.ir.v2
chuangmi.remote.h102a03
chuangmi.remote.v2
chuangmi.remote.h102c01
For now, pronto hex codes only work on the first version (chuangmi.ir.v2
Actions
The Xiaomi IR Remote Platform registers four actions.
remote.send_command
Allows sending either named commands using an identifier or sending commands as one of the two types defined in Command Types.
Used to learn new commands.
Use the entity_id of the Xiaomi IR Remote to start a learning process.
slot
and timeout
can be specified, but multiple commands learned to the same slot can still be sent using remote.send_command
even if they are overwritten.
After learning the command the base64 string can be found as a notification in Overview, the string can be copied by left clicking on the string and choose the copy option.
xiaomi_miio.remote_set_led_on
Used to turn remote’s blue LED on.
xiaomi_miio.remote_set_led_off
Used to turn remote’s blue LED off.
The xiaomi_miio
vacuum platform allows you to control the state of your Xiaomi Mi Robot Vacuum
Currently supported actions are:
start
pause
stop
return_to_base
locate
clean_spot
set_fan_speed
Fan speeds:Silent
,Standard
,Medium
,Turbo
andGentle
(exclusively for mopping). xiaomi_clean_zone
xiaomi_clean_segment
xiaomi_goto
remote_control_*
(of your robot)
Actions
In addition to all of the actions provided by the vacuum
integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] (start
, pause
, stop
, return_to_base
, locate
, set_fan_speed
and send_command
), the xiaomi_miio
platform introduces specific actions to access the remote control mode of the robot. These are:
xiaomi_miio.vacuum_clean_zone
xiaomi_miio.vacuum_clean_segment
xiaomi_miio.vacuum_goto
xiaomi_miio.vacuum_remote_control_start
xiaomi_miio.vacuum_remote_control_stop
xiaomi_miio.vacuum_remote_control_move
xiaomi_miio.vacuum_remote_control_move_step
Action xiaomi_miio.vacuum_clean_zone
Start the cleaning operation in the areas selected for the number of repeats indicated.
Data attribute:
entity_id
- Description: Only act on a specific robot.
- Optional: No.
Data attribute:
zone
Description: List of zones. Each zone is an array of four integer values. These values represent two sets of x- and y-axis coordinates that describe the beginning and ending points of a square or rectangle cleaning zone. For example,
[[23510,25311,25110,26361]]
creates a box that starts in one corner at the 23510, 25311 (x- and y-axis) coordinates and then is expanded diagonally to the 25110, 26361 coordinates to create a rectangular cleaning zone. - Optional: No.
Data attribute:
repeats
- Description: Number of cleaning repeats for each zone between 1 and 3.
- Optional: No.
Example of xiaomi_miio.vacuum_clean_zone
use:
Inline array:
automation:
- alias: "Test vacuum zone3"
triggers:
- trigger: homeassistant
event: start
actions:
- action: xiaomi_miio.vacuum_clean_zone
entity_id: vacuum.xiaomi_vacuum
repeats: "{{states('input_number.vacuum_passes')|int}}"
zone: [[30914, 26007, 35514, 28807], [20232, 22496, 26032, 26496]]
Array with inline zone:
automation:
triggers:
event: start
actions:
zone:
- [30914, 26007, 35514, 28807]
- [20232, 22496, 26032, 26496]
Array mode:
automation:
triggers:
event: start
actions:
repeats: 1
zone:
- - 30914
- 26007
- 35514
- 28807
- - 20232
- 22496
- 26032
- 26496
Action xiaomi_miio.vacuum_clean_segment
Clean the specified segment/room. A room is identified by a number. Instructions on how to find the valid room numbers and determine what rooms they map to, read the section Retrieving room numbers.
Data attribute:
entity_id
- Optional: No.
Data attribute:
segments
- Description: List of segment numbers or one single segment number.
- Optional: No.
Example of xiaomi_miio.vacuum_clean_segment
use:
Multiple segments:
automation:
- alias: "Vacuum kitchen and living room"
triggers:
event: start
actions:
- action: xiaomi_miio.vacuum_clean_segment
segments: [1, 2]
Single segment:
automation:
- alias: "Vacuum kitchen"
triggers:
event: start
actions:
segments: 1
The original app for Xiaomi vacuum has a nice feature of room cleaning with repetition, you can achieve the same result with repeating segments:
automation:
triggers:
event: start
actions:
segments: [1, 1]
Action xiaomi_miio.vacuum_goto
Go the specified coordinates.
Data attribute:
entity_id
- Optional: No.
Data attribute:
x_coord
- Description: X-coordinate, integer value. The dock is located at x-coordinate 25500.
- Optional: No.
Data attribute:
y_coord
- Description: Y-coordinate, integer value. The dock is located at y-coordinate 25500.
- Optional: No.
Note: If your vacuum is in motion and does not respond to the xiaomi_miio.vacuum_goto
command, call the vacuum.pause
or vacuum.stop
action first.
Action xiaomi_miio.vacuum_remote_control_start
Start the remote control mode of the robot. You can then move it with remote_control_move
; when done, call remote_control_stop
entity_id |
no | Only act on a specific robot |
Action xiaomi_miio.vacuum_remote_control_stop
Exit the remote control mode of the robot.
entity_id |
Action xiaomi_miio.vacuuNm_remote_control_move
Remote control the robot. Please ensure you first set it in remote control mode with remote_control_start
entity_id
: Only act on a specific robot. Not optional. -
velocity
: Speed: between -0.29 and 0.29. Not optional. -
rotation
: Rotation: between -179 degrees and 179 degrees. Not optional. -
duration
: The number of milliseconds that the robot should move for. Not optional.
Action xiaomi_miio.vacuum_remote_control_move_step
Enter remote control mode, make one move, stop, and exit remote control mode.
- entity_id: Only act on a specific robot. Not optional.
- velocity: Speed: between -0.29 and 0.29. Not optional.
- rotation: Rotation: between -179 degrees and 179 degrees. Not optional.
- duration: The number of milliseconds that the robot should move for. Not optional.
Buttons
Reset Main Brush | Resets main brush remaining lifespan |
Reset Side Brush | Resets side brush remaining lifespan |
Reset Filter | Resets filter remaining lifespan |
Reset Sensor Dirty | Resets sensor dirtiness (remaining time before needs to be cleaned) |
Sensors
The current cleaning time of the vacuum. If the vacuum is not cleaning, this sensor will have the same value as the “Last Clean Duration” sensor.
The current area that has been cleaned. If the vacuum is not cleaning, this sensor will have the same value as the “Last Clean Area” sensor.
* Needs to be manually enabled once the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] has been added.
** Only enabled if the vacuum has a mop.
Attributes
The vacuums from the xiaomi
platform does not expose additional attributes other the ones provided by the vacuum
integration,
Example on how to clean a specific room
Example script using vacuum.send_command
to clean a specific room:
vacuum_kitchen:
alias: "Clean the kitchen"
sequence:
- action: vacuum.send_command
entity_id: vacuum.xiaomi_vacuum_cleaner
command: app_segment_clean
params: [18]
Where params specify room numbers, for multiple rooms, params can be specified like [17,18]
Example on how to reset maintenance hours (brushes, filter, sensors)
The vacuum entity stores attribute values for when brushes, filters and sensors need to be
cleaned or replaced (main_brush_left
, side_brush_left
, filter_left
and
sensor_dirty_left
). The values are measured in hours. Once the parts are cleaned
or replaced you can then reset those values on the vacuum. Here is an example script using
vacuum.send_command
to reset the hours for the main brush:
reset_main_brush_left:
alias: "Reset hours for main brush replacement"
sequence:
- action: vacuum.send_Command
command: reset_consumable
params: ["main_brush_work_time"]
Allowed params
for the reset_consumable
command:
['main_brush_work_time']
['side_brush_work_time']
['filter_work_time']
['sensor_dirty_time']
Retrieving Zoned Cleaning Coordinates
Using FloleVac (Android)
- Download FloleVac
- Login with your Xiaomi credentials
- Open Map (make sure you’re on the same network as your vacuum cleaner)
- Select “Zone cleanup” and draw a box around the zone you’d like to clean
- Long press “Cleanup” and the zone coordinates will be copied to your clipboard
Using RoboRock Control Center (requires Valetudo firmware)
RRCC
Using the map editor you are able to acquire the coordinates required for zoned clean up. Here is an example script for zoned clean up:
vacuum_kitchen:
alias: "vacuum kitchen"
sequence:
entity_id: "vacuum.xiaomi_vacuum_cleaner"
command: app_zoned_clean
params: [[23084, 26282, 27628, 29727, 1]]
Retrieving Room numbers
Valid room numbers can be retrieved using miio command-line tool:
miiocli roborockvacuum --ip <ip of the vacuum> --token <your vacuum token> get_room_mapping
It will return the full mapping of room numbers to user-defined names as a list of (number,name) tuples.
Alternatively, one can just test the clean_segment
action with a number and see which room it cleans.
It seems to be the case that Numbers 1..15 are used to number the initial segmentation done by the vacuum cleaner itself. Numbers 16 and upwards numbers rooms from the users manual editing.
The xiaomi_miio
platform allows you to control the state of your Xiaomi Philips LED Ball Lamp, Xiaomi Philips Zhirui LED Bulb E14 Candle Lamp, Xiaomi Philips Zhirui Downlight, Xiaomi Philips LED Ceiling Lamp, Xiaomi Philips Eyecare Lamp 2, Xiaomi Philips Moonlight Bedside Lamp and Philips Zhirui Desk Lamp.
Features
Philips LED Ball Lamp, Philips Zhirui LED Candle Lamp and Philips Zhirui Downlight
Supported models: philips.light.bulb
, philips.light.candle
, philips.light.candle2
, philips.light.downlight
- Power (on, off)
- Brightness
- Color temperature (175…333 mireds)
- Scene (1, 2, 3, 4)
- Delayed turn off (Resolution in seconds)
- Attributes
- model
- scene
- delayed_turn_off
Supported models: philips.light.ceiling
, philips.light.zyceiling
- Power (on, off)
- Brightness
- Color temperature (175…370 mireds)
- Night light mode (on, off)
- Attributes
- model
- scene
- delayed_turn_off
- night_light_mode
- automatic_color_temperature
Philips Eyecare Smart Lamp 2
Supported models: philips.light.sread1
- Eyecare light (on, off)
- Ambient light (on, off)
- Brightness (of each light)
- Eye fatigue reminder / notification (on, off)
- Eyecare mode (on, off)
- Attributes
- model
- scene
- delayed_turn_off
- night_light_mode
- reminder
- eyecare_mode
Supported models: philips.light.mono1
- Power (on, off)
- Brightness
- Attributes
- model
- scene
- delayed_turn_off
Supported models: philips.light.moonlight
- Power (on, off)
- Brightness
- Color
- Color temperature (153…588 mireds)
- Scene (1, 2, 3, 4, 5, 6)
- Attributes
- model
- scene
- sleep_assistant
- sleep_off_time
- total_assistant_sleep_time
- brand_sleep
- brand
Actions
Action xiaomi_miio.light_set_scene
Set one of the 4 available fixed scenes.
entity_id |
no | Only act on a specific Xiaomi miIO light entity. |
scene |
no | Scene, between 1 and 4. |
Action xiaomi_miio.light_set_delayed_turn_off
Delayed turn off.
entity_id |
time_period |
no | Time period for the delayed turn off. |
Action xiaomi_miio.light_reminder_on (Eyecare Smart Lamp 2 only)
Enable the eye fatigue reminder/notification.
entity_id |
Action xiaomi_miio.light_reminder_off (Eyecare Smart Lamp 2 only)
Disable the eye fatigue reminder/notification.
entity_id |
Action xiaomi_miio.light_night_light_mode_on (Eyecare Smart Lamp 2 only)
Turn the smart night light mode on.
entity_id |
Action xiaomi_miio.light_night_light_mode_off (Eyecare Smart Lamp 2 only)
Turn the smart night light mode off.
entity_id |
Action xiaomi_miio.light_eyecare_mode_on (Eyecare Smart Lamp 2 only)
Turn the eyecare mode on.
entity_id |
Action xiaomi_miio.light_eyecare_mode_off (Eyecare Smart Lamp 2 only)
Turn the eyecare mode off.
entity_id |
The xiaomi_miio
switch platform allows you to control the state of your Xiaomi Smart WiFi Socket aka Plug, Xiaomi Smart Power Strip and Xiaomi Chuangmi Plug V1.
Features
Supported models: chuangmi.plug.m1
, chuangmi.plug.m3
, chuangmi.plug.v2
, chuangmi.plug.hmi205
, chuangmi.plug.hmi206
- Power (on, off)
- Attributes
- Temperature
Supported models: chuangmi.plug.v1
, chuangmi.plug.v3
, chuangmi.plug.hmi208
- Power (on, off)
- USB (on, off)
- Attributes
- Temperature
Supported models: qmi.powerstrip.v1
, zimi.powerstrip.v2
- Power (on, off)
- Wifi LED (on, off)
- Power Price (0…999)
- Power Mode (green, normal) (Power Strip V1 only)
- Attributes
- Temperature
- Current
- Load power
- Wifi LED
- Mode (Power Strip V1 only)
Xiaomi Air Conditioning Companion V3
Supported models: lumi.acpartner.v3
(the socket of the acpartner.v1
and v2
isn’t switchable!)
- Power (on, off)
- Attributes
- Load power
Actions
Action xiaomi_miio.switch_set_wifi_led_on (Power Strip only)
Turn the wifi LED on.
entity_id |
no | Only act on a specific Xiaomi miIO switch entity. |
Action xiaomi_miio.switch_set_wifi_led_off (Power Strip only)
Turn the wifi LED off.
entity_id |
Action xiaomi_miio.switch_set_power_price (Power Strip)
Set the power price.
entity_id |
price |
no | Power price, between 0 and 999. |
Action xiaomi_miio.switch_set_power_mode (Power Strip V1 only)
Set the power mode.
entity_id |
mode |
no | Power mode, valid values are ‘normal’ and ‘green’ |
Not recommended, please specify the cloud credentials during the config flow for easier setup. However when setting up a device manually the token can be retrieved in one of the following ways.
Xiaomi Cloud Tokens Extractor
One of Home Assistant users wrote a tokens extractor tool, which is currently the easiest way to retrieve tokens for all devices assigned to Xiaomi account.
In the repository
- Install requirements:
pip3 install pycryptodome pybase64 requests
- Run script
python3 token_extractor.py
- Provide email address or username for Xiaomi’s account, password and country of the account (most used: CN - China Mainland, DE - Germany etc.)
- Script will print out all devices connected to the account with their IP address and tokens for use in Home Assistant.
Xiaomi Home app (Xiaomi Aqara Gateway, Android & iOS)
- Install the Xiaomi Home app.
- Sign In/make an account.
- Make sure you set your region to: Mainland China (Seems to be the longest line with Chinese characters) under settings -> Region (language can later be set on English).
- Select your Gateway in Xiaomi Home app.
- Then the 3 dots at the top right of the screen.
- Then click on about.
- Tap the version number (Plug-in version 2.77.1 as of January 2020, iOS has a white space instead of version number) at the bottom of the screen repeatedly.
- You should now see 2 extra options listed in English (iOS still in Chinese), this means you enabled developer mode. [if not, try all steps again!].
- Android: under “Hub info” there is quite some text in JSON format, this includes the “token” that you need. iOS: Most options are still in Chinese, you need the fourth item from the top.
Note: If you have multiple devices needing a token, e.g., Xiaomi Mi Robot Vacuum and a Xiaomi IR Remote, the above method may not work. The Xiaomi Home app will display a token, though it isn’t the correct one. The alternative method using “Mi Home v5.4.49” will provide the correct token.
Using Get Mi Home Devices Token App
If you are on a Windows or macOS device, you can use the Get MiHome devices token
Alternative methods
If using an Android device to retrieve the Access Token only v5.4.49
of Mi Home is confirmed working (December 2019). Use v5.4.49
of Mi Home locate a text file under the Smarthome/logs
folder where the 32 character token is stored. There will likely be several text files in this directory, search all of them for the word ‘token’ and you should find it there. Be advised that the latest version of Mi Home does not store the token in clear text.
The iPhone app still stores the token in the SQLite db as of v4.23.4
(Nov 17, 2019).
After resetting the Wi-Fi settings of the Xiaomi robot vacuum, a new Access Token will be generated and therefore these instructions need to be followed again.
These instructions are written for the Mi Home app - not for the new RoboRock app.
This token (32 hexadecimal characters) is required for the Xiaomi Mi Robot Vacuum, Mi Robot 2 (Roborock) Vacuum, Xiaomi Philips Lights and Xiaomi IR Remote.
Android (not rooted)
v5.4.49
- To begin, set up your Robovac with the latest version of Mi Home on your primary Android device as you normally would.
- If your Robovac is already set up, you must reset its WiFi settings for it to get a new token.
- Using
v5.4.49
of Mi Home locate a text file under theSmarthome/logs
folder where the 32 character token is stored. - There will likely be several text files in this directory, search all of them for the word ‘token’ and you should find it there. Be advised that the latest version of Mi Home does not store the token in clear text.
Linux and Rooted Android
- Ensure successful operation using the latest Mi Home app and give the Vacuum a static IP in your router or however you do that on your LAN.
- Install version
v5.4.54
of Mi Home on your rooted Android device and login (you can’t have two version of Mi Home installed at the same time). - Ensure you are using the same server every time
- Ensure successful operation using 5.4.54 (locate is a nice simple test)
- Using adb we will now extract the token from the rooted phone
- Use adb shell to connect to your device and become root (if using Magisck root do
adb shell -> su -> whoami
to ensure root access. - Then run grep -R ‘“token”’ /data/data/com.xiaomi.smarthome and grab the token
iOS
Configure the robot with the Mi Home app. Make sure to select the correct region, as Xiaomi uses different product names for different geographical areas. Note that the new RoboRock app is currently not supported for this method.
Using iTunes, create an unencrypted backup of your iPhone. Since macOS 10.15 there is no iTunes app. Use Finder instead - after connecting your iOS device you should see it in left menu of Finder window.
Install iBackup Viewer
, open it, and open your backup. -
Open the “Raw Data” module.
Navigate to
com.xiaomi.mihome
Search for a file that looks like this:
123456789_mihome.sqlite
(Note:_mihome.sqlite
is not the correct file. Most likely, you will find this file in theDocuments
folder.) -
Save this file to your filesystem.
Install DB Browser for SQLite
Open DB Browser and load the
.sqlite
file you saved from your backup. -
Click on the
Execute SQL
tab. -
Input and run this query (use appropriate SELECT query for your device i.e. Vacuum, Powerstrip or Plug):
-- Execute to retrieve token for Vacuum SELECT ZTOKEN FROM ZDEVICE WHERE ZMODEL LIKE "%vacuum%" -- Execute to retrieve token for Smart Powerstrip SELECT ZTOKEN FROM ZDEVICE WHERE ZMODEL LIKE "%powerstrip%" -- Execute to retrieve token for Smart Plug SELECT ZTOKEN FROM ZDEVICE WHERE ZMODEL LIKE "%plug%"
Copy the returned 96-digit hexadecimal string to your clipboard.
Open
Terminal
and execute this command:echo '0: <YOUR HEXADECIMAL STRING>' | xxd -r -p | openssl enc -d -aes-128-ecb -nopad -nosalt -K 00000000000000000000000000000000
Use the resulting 32-digit string as your token. (On your mac in front of the terminal session)
Bluestacks
- Configure the robot with the Mi-Home app. Make sure to select the correct region, as Xiaomi uses different product names for different geographical areas. Note that the new RoboRock app is currently not supported for this method.
- Install BlueStacks
. - Set up Mi Home version 5.4.49
in BlueStacks and login to synchronize devices. - Open Filemanager in the
More Apps
menu. - Use
Explore
on the left and navigate tosdcard/SmartHome/logs/plug_DeviceManager
. - Click on
Export to Windows
in the lower left corner and select any or all files to export to you local disk. - Search for
"token":"<yourTokenHere>"
Miio command line tool
Use of Miio should be done before the Vacuum is connected to Mi Home. If you already connected to the app you will need to delete it and then join the ad-hoc Wi-Fi network the Vacuum creates. If the vacuum is already paired it’s likely this method will only return ???
as your token.
Discovering devices on the current network:
npx miio discover
This will list devices that are connected to the same network as your computer. Let it run for a while so it has a chance to reach all devices, as it might take a minute or two for all devices to answer.
The commands outputs each device on this format:
Device ID: 48765421
Model info: zhimi.airpurifier.m1
Address: 192.168.100.9
Token: token-as-hex-here via auto-token
Support: At least basic
The information output is:
Device ID
- The unique identifier of the device, does not change if the device is reset. -
Model ID
- The model id if it could be determined, this indicates what type of device it is. -
Address
- The IP that the device has on the network. -
Token
- The token of the device or???
if it could not be automatically determined.
Alternate method to get all yours devices tokens in one run. Please follow this instruction
