UK Transport
The uk_transport integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will display the time in minutes until the next departure in a specified direction from of a configured train station or bus stop. The sensor uses transportAPI to query live departure data and requires a developer application ID and key which can be obtained here. The free tier allows 30 requests a day, which is sufficient for a single sensor refreshing every 48 minutes.
Note
Additional sensors can be added but at the expense of a reduced refresh rate. 2 sensors can be updated every 2*48 = 96 minutes, and so on. Calculating and setting this rate is automatically handles by the integration.
Queries are entered as a list, with the two transport modes available being bus and train.
Train departure sensors require three character long origin and destination station codes which are searchable on the National Rail enquiries website (e.g., WAT is London Waterloo). The validity of a route can be checked by performing a GET request to /uk/train/station/{station_code}/live.json in the API reference webpage.
To add a single train departure integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
# Example configuration.yaml entry for a single sensor
  - platform: uk_transport
    app_id: YOUR_APP_ID
    app_key: YOUR_APP_KEY
    queries:
      - mode: train
        origin: MAL
        destination: WAT
app_id string Required
Your application ID.
app_key string Required
Your application Key.
queries list Required
At least one entry required.
mode list Required
One of bus or train.
origin string Required
Specify the three character long origin station code.
destination string Required
Specify the three character long destination station code.
A large amount of information about upcoming departures is available within the attributes of the sensor. The example above creates a sensor with ID sensor.next_train_to_wat with the attribute next_trains which is a list of the next 25 departing trains.
These attributes are available for each departing train:
  • origin_name
  • destination_name
  • status
  • scheduled: (API attribute is aimed_departure_time)
  • estimated: (API attribute is expected_departure_time)
  • platform
  • operator_name
Refer to the API reference webpage for definitions.
Attributes can be accessed using the template sensor as per this example:
# Example configuration.yaml entry for a template sensor to access the attributes of the next departing train.
template:
  - sensor:
    - name: Next train status
      state: >-
        {{state_attr('sensor.next_train_to_wat', 'next_trains')[0].status}}
    - name: Next train origin
      state: >-
        {{state_attr('sensor.next_train_to_wat', 'next_trains')[0].origin_name}}
    - name: Next train estimated
      state: >-
        {{state_attr('sensor.next_train_to_wat', 'next_trains')[0].estimated}}
    - name: Next train scheduled
      state: >-
        {{state_attr('sensor.next_train_to_wat', 'next_trains')[0].scheduled}}
    - name: Next train platform
      state: >-
        {{state_attr('sensor.next_train_to_wat', 'next_trains')[0].platform}}
Bus sensors require as their origin a bus stop ATCO code which can be found by browsing OpenStreetMap data as follows:
  1. On OpenStreetMap.org zoom right in on a bus stop you’re interested in.
  2. Click the layers picker button on the right hand side.
  3. Tick the ‘map data’ layer, and wait for clickable objects to load.
  4. Click the bus stop node to reveal its tags on the left.
The destination must be a valid location in the “direction” field returned by a GET query to /uk/bus/stop/{atcocode}/live.json as described in the API reference webpage. A bus sensor is added in the following configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file entry:
# Example configuration.yaml entry for multiple sensors
    app_id: YOUR_APP_ID
    queries:
      - mode: bus
        origin: 340000368SHE
        destination: Wantage
      - mode: train
        origin: MAL
        destination: WAT
And the template sensor for viewing the next bus attributes.
# Example configuration.yaml entry for a template sensor to access the attributes of the next departing bus.
template:
  - sensor:
    - name: Next bus route
      state: "{{state_attr('sensor.next_bus_to_wantage', 'next_buses')[0].route}}"
    - name: Next bus direction
      state: "{{state_attr('sensor.next_bus_to_wantage', 'next_buses')[0].direction}}"
    - name: Next bus scheduled
      state: "{{state_attr('sensor.next_bus_to_wantage', 'next_buses')[0].scheduled}}"
    - name: Next bus estimated
      state: "{{state_attr('sensor.next_bus_to_wantage', 'next_buses')[0].estimated}}"
Managing API requests
If you wish to manage the rate of API requests (e.g., to disable requests when you aren’t interested in travel, so that you can request updates more frequently when you do travel) set a really long scan_interval in the configuration options, and use the homeassistant.update_entity action to request the update of an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more], rather than waiting for the next scheduled update.
Powered by transportAPI
