Trafikverket Weather Station
Showing weather information provided by Trafikverket
Potential use cases
- Get weather data in general.
- You live near a weather station and want to know the current weather conditions at home.
- Setup automations for your car heating system. If the road is frozen along the way to work, you might want the car heating system to start earlier.
Please click here
To add the Trafikverket Weather Station integration to your Home Assistant instance, use this My button:
From the list, select Trafikverket Weather Station.
Entities provided by the integration
- Air temperature.
- Road temperature.
- Dew point
- Relative humidity.
- Precipitation type.
- Precipitation amount
- Wind direction in degrees.
- Wind speed
Entities provided but not enabled by default
- Maximum wind speed measured during the last 30 minutes
- Measurement time
- Visible distance
- Road ice depth
- Road snow depth
- Road water depth
- Road water equivalent depth
- Wind measurement height
- Data modified time
Weather stations
To get a map of valid weather stations, open the trafikverket websitestation
variable.
