Trafikverket Train
Retrieve train departure information from Trafikverket.
Use cases
  • Retrieve the next departure between two stations.
  • Retrieve information for specific departure time between two stations.
  • Set up an alert or perform actions if your train is delayed or canceled.
Retrieved data
  • Next departure for the specific train line.
  • Canceled status.
  • Delayed time.
  • Planned time if no delays occur.
  • Estimated time of arrival if delays occur.
  • Actual time - when it did arrive.
  • Other information / additional texts.
  • Deviations.
The next departure is calculated from actual, estimated, and planned to provide the most accurate information about departure.
If a specific departure time has not been set, the integration will return the 3 next departures.
You can filter based on product descriptions such as SJ Regionaltåg to only see specific trains between the two stations.
Please click here and register to obtain the API key.
To add the Trafikverket Train integration to your Home Assistant instance, use this My button:
  • From the list, select Trafikverket Train.
Train station names
Click here to see examples of train station names.
