Traccar Server
Traccar uses GPS for tracking and has support for over 1500 different types of devices. You can use the Traccar Server integration to communicate with your own Traccar Server, which is also available as Home Assistant add-on.
Looking for documentation on how to setup the Traccar Client with webhooks in Home Assistant? See the Traccar Client integration documentation.
To add the Traccar Server integration to your Home Assistant instance, use this My button:
From the list, select Traccar Server.
Events
The Traccar Server integration options allow you to define a list of events you want to listen for. These events will be sent to Home Assistant as events.
All events will be prefixed with traccar_
followed by a snake_cased version of the event name.
Examples:
- The
deviceMoving
will be fired in Home Assistant astraccar_device_moving
. - The
geofenceExit
will be fired in Home Assistant astraccar_geofence_exit
. - The
alarm
will be fired in Home Assistant astraccar_alarm
All events will also have the following data:
"device_traccar_id": 24,
"device_name": "My Device",
"type": "alarm",
"serverTime": "1970-01-01T00:00:00.000Z",
"attributes": {
"custom_attribute": "value"
Devices
The Traccar Server integration will create devices for each device registered in the Traccar Server with at least one position update.
These device representations in Home Assistant will have entities associated with them, which you can use in automations, scripts, and display on your dashboard.
Entities
The traccar server integration will create entities in with the following domains:
For more details about each of these, see the sections below.
Binary Sensor - Motion
The Traccar Server integration will create a binary_sensor entity for each device registered in Traccar Server to show the motion reported by the Traccar Server.
This entity is disabled by default.
The name of the sensor will be set to what you have named it in Traccar Server, followed by the term “Motion”. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Motion”.
This will be the unique ID of the device tracker in Traccar Server followed by position_attributes_motion
This entity does not have any attributes.
Binary Sensor - Status
The Traccar Server integration will create a binary_sensor entity for each device registered in Traccar Server to show the status reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by the term “Status”. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Status”.
This will be the unique ID of the device tracker in Traccar Server followed by device_status
Device Tracker
The Traccar Server integration will create a device tracker entity for each device registered in Traccar Server.
In addition to the custom attributes you can define in the Traccar Server integration options, the device tracker entity will have the following attributes:
Sensor - Address
The Traccar Server integration will create a sensor entity for each device registered in Traccar Server to show the address reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by Address. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Address”.
This will be the unique ID of the device tracker in Traccar Server followed by position_address
Sensor - Altitude
The Traccar Server integration will create a sensor entity for each device registered in Traccar Server to show the altitude reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by Altitude. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Altitude”.
This will be the unique ID of the device tracker in Traccar Server followed by position_altitude
Sensor - Battery
The Traccar Server integration will create a sensor entity for each device registered in Traccar Server to show the remaining battery percentage reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by Battery. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Battery”.
This will be the unique ID of the device tracker in Traccar Server followed by position_attributes.batteryLevel
Sensor - Geofence
The Traccar Server integration will create a sensor entity for each device registered in Traccar Server to show the geofence reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by Geofence. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Geofence”.
This will be the unique ID of the device tracker in Traccar Server followed by geofence_geofence
Sensor - Speed
The Traccar Server integration will create a sensor entity for each device registered in Traccar Server to show the speed reported by the Traccar Server.
The name of the sensor will be set to what you have named it in Traccar Server followed by Speed. If your device is named “Millennium Falcon”, this will be “Millennium Falcon Speed”.
This will be the unique ID of the device tracker in Traccar Server followed by position_speed
Examples
So you set up the integration and it pulled in all your devices. Now what? Below are some examples of what you can do with the data provided by Traccar Server integration.
Automations
In this section you will find some example automations that you can use to get started with the Traccar Server integration.
Do something when a device enters a geofence
The allows you to do something when the device “Millennium Falcon” enters the defined geofence.
trigger:
- platform: state
entity_id: sensor.millennium_falcon_geofence
to: 'Tatooine'
action:
Do something when a device are speeding
The allows you to do something when the device “Millennium Falcon” exceeds a defined speed.
trigger:
- platform: numeric_state
entity_id: sensor.millennium_falcon_speed
above: 1337
action:
If you want to include the speed in a notification, you can use the `` template.
Partial example:
trigger:
action:
- service: notify.notify
message: "The current speed of the Millennium falcon is !"
