Telegram bot
Use Telegram on your mobile or desktop device to send and receive messages or commands to/from your Home Assistant.
This integration creates notification actions to send, edit or receive messages from a Telegram Bot account
Introduction - Telegram bot platforms
Platforms are Telegram bot implementations for managing communications with Telegram for sending and receiving messages. When setting up this integration, you should specify the platform which fits your environment and use case.
Broadcast
Telegram implementation to support sending messages only. Your Home Assistant instance does not have to be exposed to the internet and there is no polling to receive messages or commands sent to the bot.
Polling
Telegram chatbot polling implementation. Your Home Assistant instance does not have to be exposed to the internet.
Webhooks
Telegram chatbot webhooks implementation as described in the Telegram documentation
Create Telegram bot
Create your Telegram bot and retrieve the API key. The api_key
will be used for adding the bot to Home Assistant during integration setup.
Allow Telegram bot to access your Home Assistant files (Optional)
To enable Telegram bot to send local files, you must grant access to it by adding the file’s folder to allowlist_external_dirs
Example configuration.yaml
homeassistant:
allowlist_external_dirs:
- "/media"
Allow Telegram to connect to your Home Assistant (Webhooks platform only)
This integration currently does not support self-signed certificates for HTTPS. If you are using the Reverse proxy or Direct method, please ensure that your certificates are signed by a public Certificate Authority (CA).
If you plan to use the Webhooks
platform, you will need to allow Telegram to connect to your Home Assistant using one of the following methods:
Home Assistant Cloud
If you have a Home Assistant Cloud subscription, you can enable remote access
Reverse proxy
If your Home Assistant is behind a publicly accessible reverse proxy (for example NGINX, Caddy, Traefik) with HTTPS enabled, do the following:
- Go to Settings > System > Network and configure Home Assistant URL.
- Configure the HTTP integration to allow Home Assistant to accept connections from your reverse proxy:
- Set
use_x_forwarded_for
totrue
. - Add the IP address of the reverse proxy to
trusted_proxies
- Set
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.0.0/16
Direct
If your Home Assistant is publicly accessible, do the following:
- Configure the HTTP integration to enable HTTPS on your Home Assistant by configuring the following variables:
server_host
server_port
ssl_certificate
ssl_key
To add the Telegram bot integration to your Home Assistant instance, use this My button:
From the list, select Telegram bot.
Webhooks configuration
If you have selected the Webhooks
Telegram bot type, the integration setup will continue with the webhooks configuration step.
Allow to overwrite the external URL from the Home Assistant configuration for different setups (https://<public_url>:<port>
Options
Options for Telegram bot can be set via the user interface, by taking the following steps:
- Browse to your Home Assistant instance.
- Go to Settings > Devices & Services.
- If multiple instances of Telegram bot are configured, choose the instance you want to configure.
- Select the integration, then select Configure.
The integration can be configured to use a default parse mode for messages.
Default parser for messages if not explicit in message data, either markdown
(legacy), markdownv2
, html
or plain_text
. Refer to Telegram’s formatting options
Allowlisting chat IDs via Subentries
A Telegram chat ID is a unique numerical identifier for an individual user (positive) or a chat group (negative). You must allowlist the chat ID for the Telegram bot before it can send/receive messages for that chat. To allowlist the chat ID, retrieve the chat ID and create a subentry:
- Select the Telegram bot integration.
menu. Then, select Add allowed chat ID.
Notification actions
Available actions: send_message
, send_photo
, send_video
, send_animation
, send_voice
, send_sticker
, send_document
, send_location
, edit_message
, edit_caption
, edit_replymarkup
, answer_callback_query
, delete_message
, leave_chat
and set_message_reaction
Actions that send contents (send_*
) will return a list of message_id
/chat_id
for messages delivered (in a property called chats
). This will populate Response Data that you can further utilize in your automations to edit/delete the message later based on the message_id
. See the example later on this page for usage instructions.
Action telegram_bot.send_message
Send a notification.
config_entry_id |
yes | The config entry representing the Telegram bot to send the message. Required if you have multiple Telegram bots. |
message |
no | Message body of the notification. |
title |
yes | Optional title for your notification. Will be composed as ‘%title\n%message’. |
target |
yes | An array of pre-authorized chat_ids or user_ids to send the notification to. Defaults to the first allowed chat_id. |
parse_mode |
yes | Parser for the message text: markdownv2 , html , markdown or plain_text . |
disable_notification |
yes | True/false for send the message silently. iOS users and web users will not receive a notification, Android users will receive a notification with no sound. Defaults to False. |
disable_web_page_preview |
yes | True/false for disable link previews for links in the message. |
resize_keyboard |
yes | True/false for resizing the keyboard vertically for optimal fit. Defaults to False. |
one_time_keyboard |
yes | True/false for hiding the keyboard as soon as it’s been used. The keyboard will still be available, but clients will automatically display the usual letter keyboard in the chat - the user can press a special button in the input field to see the custom keyboard again. Defaults to False. |
keyboard |
yes | List of rows of commands, comma-separated, to make a custom keyboard. [] to reset to no custom keyboard. Example: ["/command1, /command2", "/command3"]
inline_keyboard |
yes | List of rows of commands, comma-separated, to make a custom inline keyboard with buttons with associated callback data or external URL (https-only). Example: ["/button1, /button2", "/button3"] or [[["Text btn1", "/button1"], ["Text btn2", "/button2"]], [["Google link", "https://google.com"]]]
message_tag |
yes | Tag for sent message. In telegram_sent event data: {{trigger.event.data.message_tag}}
reply_to_message_id |
yes | Mark the message as a reply to a previous message. In telegram_callback handling, for example, you can use {{ trigger.event.data.message.message_id }}
message_thread_id |
yes | Send the message to a specific topic or thread. |
Action telegram_bot.send_photo
Send a photo.
config_entry_id |
yes | The config entry representing the Telegram bot to send the photo. Required if you have multiple Telegram bots. |
url |
no | Remote path to an image. |
file |
no | Local path to an image. |
caption |
yes | The title of the image. |
username |
yes | Username for a URL which requires HTTP authentication. |
password |
yes | Password (or bearer token) for a URL which require HTTP authentication. |
authentication |
yes | Define which authentication method to use. Set to digest to use HTTP digest authentication, or bearer_token for OAuth 2.0 bearer token authentication. Defaults to basic . |
target |
parse_mode |
verify_ssl |
yes | True/false for checking the SSL certificate of the server for HTTPS URLs. Defaults to True. |
timeout |
yes | Timeout for sending photo in seconds. Will help with timeout errors (poor internet connection, etc) |
resize_keyboard |
one_time_keyboard |
yes | True/false for hiding the keyboard as soon as it’s been used. The keyboard will still be available, but clients will automatically display the usual letter-keyboard in the chat - the user can press a special button in the input field to see the custom keyboard again. Defaults to False. |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_video
Send a video.
config_entry_id |
yes | The config entry representing the Telegram bot to send the video. Required if you have multiple Telegram bots. |
url |
no | Remote path to a video. |
file |
no | Local path to a video. |
caption |
yes | The title of the video. |
username |
password |
authentication |
target |
parse_mode |
yes | True/false to send the message silently. iOS users and web users will not receive a notification. Android users will receive a notification with no sound. Defaults to False. |
verify_ssl |
timeout |
yes | Timeout for sending video in seconds. Will help with timeout errors (poor internet connection, etc) |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_thread_id |
Action telegram_bot.send_animation
Send an animation.
config_entry_id |
yes | The config entry representing the Telegram bot to send the animation. Required if you have multiple Telegram bots. |
url |
no | Remote path to a GIF or H.264/MPEG-4 AVC video without sound. |
file |
no | Local path to a GIF or H.264/MPEG-4 AVC video without sound. |
caption |
yes | The title of the animation. |
username |
password |
authentication |
target |
parse_mode |
verify_ssl |
timeout |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_voice
Send a voice message.
config_entry_id |
yes | The config entry representing the Telegram bot to send the voice message. Required if you have multiple Telegram bots. |
url |
no | Remote path to a voice message. |
file |
no | Local path to a voice message. |
caption |
yes | The title of the voice message. |
username |
password |
authentication |
target |
verify_ssl |
timeout |
yes | Timeout for sending voice in seconds. Will help with timeout errors (poor internet connection, etc) |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_sticker
Send a sticker.
config_entry_id |
yes | The config entry representing the Telegram bot to send the sticker. Required if you have multiple Telegram bots. |
url |
no | Remote path to a static .webp or animated .tgs sticker. |
file |
no | Local path to a static .webp or animated .tgs sticker. |
sticker_id |
no | ID of a sticker that exists on telegram servers. The ID can be found by sending a sticker to your bot and querying the telegram-api method getUpdates |
username |
password |
authentication |
target |
verify_ssl |
timeout |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_document
Send a document.
config_entry_id |
yes | The config entry representing the Telegram bot to send the document. Required if you have multiple Telegram bots. |
url |
no | Remote path to a document. |
file |
no | Local path to a document. |
caption |
yes | The title of the document. |
username |
password |
authentication |
target |
parse_mode |
verify_ssl |
timeout |
yes | Timeout for sending document in seconds. Will help with timeout errors (poor internet connection, etc) |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_location
Send a location.
config_entry_id |
yes | The config entry representing the Telegram bot to send the location. Required if you have multiple Telegram bots. |
latitude |
no | The latitude to send. |
longitude |
no | The longitude to send. |
target |
yes | An array of pre-authorized chat_ids or user_ids to send the notification to. Defaults to the first allowed chat_id . |
resize_keyboard |
one_time_keyboard |
keyboard |
inline_keyboard |
message_tag |
message_thread_id |
Action telegram_bot.send_poll
Send a poll.
config_entry_id |
yes | The config entry representing the Telegram bot to send the poll. Required if you have multiple Telegram bots. |
question |
no | Poll question, 1-300 characters. |
options |
no | List of answer options, 2-10 strings 1-100 characters each. |
target |
is_anonymous |
yes | True/false for if the poll needs to be anonymous, defaults to True. |
allows_multiple_answers |
yes | True/false for if the poll allows multiple answers, defaults to False. |
open_period |
yes | Amount of time in seconds the poll will be active after creation, 5-600. |
timeout |
message_thread_id |
Action telegram_bot.edit_message
Edit a previously sent message in a conversation.
config_entry_id |
yes | The config entry representing the Telegram bot to edit the message. Required if you have multiple Telegram bots. |
message_id |
no | Id of the message to edit. When answering a callback from a pressed button, the id of the origin message is in: {{ trigger.event.data.message.message_id }} . You can use "last" to refer to the last message sent to chat_id . |
chat_id |
no | The chat_id where to edit the message. |
message |
title |
parse_mode |
inline_keyboard |
Action telegram_bot.edit_caption
Edit the caption of a previously sent message.
config_entry_id |
yes | The config entry representing the Telegram bot to edit the caption. Required if you have multiple Telegram bots. |
message_id |
chat_id |
no | The chat_id where to edit the caption. |
caption |
inline_keyboard |
Action telegram_bot.edit_replymarkup
Edit the inline keyboard of a previously sent message.
config_entry_id |
yes | The config entry representing the Telegram bot to edit the inline keyboard. Required if you have multiple Telegram bots. |
message_id |
chat_id |
no | The chat_id where to edit the reply_markup. |
inline_keyboard |
Action telegram_bot.answer_callback_query
Respond to a callback query originated by clicking on an online keyboard button. The answer will be displayed to the user as a notification at the top of the chat screen or as an alert.
config_entry_id |
yes | The config entry representing the Telegram bot to answer the callback query. Required if you have multiple Telegram bots. |
message |
no | Unformatted text message body of the notification. |
callback_query_id |
no | Unique id of the callback response. In the telegram_callback event data: {{ trigger.event.data.id }}
show_alert |
yes | True/false for show a permanent notification. Defaults to False. |
Action telegram_bot.delete_message
Delete a previously sent message in a conversation.
config_entry_id |
yes | The config entry representing the Telegram bot to delete the message. Required if you have multiple Telegram bots. |
message_id |
no | Id of the message to delete. When answering a callback from a pressed button, the id of the origin message is in: {{ trigger.event.data.message.message_id }} . You can use "last" to refer to the last message sent to chat_id . |
chat_id |
no | The chat_id where to delete the message. |
Action telegram_bot.leave_chat
Remove the bot from the chat group where it was added.
config_entry_id |
yes | The config entry representing the Telegram bot to leave the chat. Required if you have multiple Telegram bots. |
chat_id |
no | The chat_id from where to remove the bot. |
Action telegram_bot.set_message_reaction
Sets the bot’s reaction for a given message.
Data data attribute | Optional | Description |
config_entry_id |
yes | The config entry representing the Telegram bot to set the message reaction. Required if you have multiple Telegram bots. |
message_id |
no | Id of the message to react to. |
chat_id |
no | Id of the chat containing the message. |
reaction |
no | Emoji to react to the message with. |
is_big |
yes | Whether to use a large variant of the reaction animation. |
Telegram notification platform
The telegram
notification platform requires the telegram_bot
integration to work with, and it’s designed to generate a customized shortcut (notify.USERNAME
) to send notifications (messages, photos, documents, and locations) to a particular chat_id
with the old syntax, allowing backward compatibility. The data attributes parse_mode
, disable_notification
, message_tag
, disable_web_page_preview
, and message_thread_id
are also supported.
The required YAML configuration now reduces to:
notify:
- platform: telegram
chat_id: USER_CHAT_ID
Event triggering
A command looks like /thecommand
or /othercommand with some args
When received by Home Assistant it will fire a telegram_command
event on the event bus with the following event_data
command: "/thecommand"
args: "<any other text following the command>"
from_first: "<first name of the sender>"
from_last: "<last name of the sender>"
user_id: "<id of the sender>"
chat_id: "<origin chat id>"
chat: "<chat info>"
date: "<message timestamp>"
message_thread_id: "<message thread id>"
Any other message not starting with /
will be processed as simple text, firing a telegram_text
text: "some text received"
chat: "<chat info>"
If the message is sent from a press from an inline buttontelegram_callback
event with:
data: "<data associated to action callback>"
message: <message origin of the action callback>
id: "<unique id of the callback>"
chat_instance: "<chat instance>"
Configuration samples
Simple ping pong example.
alias: "Telegram bot that reply pong to ping"
triggers:
- trigger: event
event_type: telegram_command
event_data:
command: "/ping"
actions:
- action: notify.notify
message: "pong"
An example that shows keyboard interaction with notify.telegram
triggers:
- trigger: event
event_data:
command: "/start"
actions:
- action: notify.telegram
message: "commands"
keyboard:
- '/ping, /alarm'
- '/siren'
and an automation to trigger a related command “/siren”.
triggers:
- trigger: event
event_data:
command: "/siren"
actions:
- action: homeassistant.turn_on
entity_id: switch.vision_zm1601eu5_battery_operated_siren_switch_9_0
- delay:
seconds: 10
- action: homeassistant.turn_off
An example to show the use of event_data in action:
- alias: "Kitchen Telegram Speak"
triggers:
- trigger: event
event_data:
command: "/speak"
actions:
- action: notify.kitchen_echo
message: >
Message from {{ trigger.event.data["from_first"] }}. {% for state in trigger.event.data["args"] %} {{ state }} {% endfor %}
Sample automations with callback queries and inline keyboards
A quick example to show some of the callback capabilities of inline keyboards with a dumb automation consisting in a simple repeater of normal text that presents an inline keyboard with 3 buttons: ‘EDIT’, ‘NO’ and ‘REMOVE BUTTON’:
- Pressing ‘EDIT’ changes the sent message.
- Pressing ‘NO’ only shows a brief notification (answering the callback query).
- Pressing ‘REMOVE BUTTON’ changes the inline keyboard removing that button.
Text repeater:
- alias: "Telegram bot that repeats text"
triggers:
- trigger: event
event_type: telegram_text
actions:
- action: telegram_bot.send_message
title: "*Dumb automation*"
target: "{{ trigger.event.data.user_id }}"
message: "You said: {{ trigger.event.data.text }}"
disable_notification: true
inline_keyboard:
- "Edit message:/edit_msg, Don't:/do_nothing"
- "Remove this button:/remove_button"
Message editor:
- alias: "Telegram bot that edits the last sent message"
triggers:
- trigger: event
event_type: telegram_callback
event_data:
command: "/edit_msg"
actions:
- action: telegram_bot.answer_callback_query
callback_query_id: "{{ trigger.event.data.id }}"
message: "Editing the message!"
show_alert: true
- action: telegram_bot.edit_message
message_id: "{{ trigger.event.data.message.message_id }}"
chat_id: "{{ trigger.event.data.chat_id }}"
title: "*Message edit*"
inline_keyboard:
message: >
Callback received from {{ trigger.event.data.from_first }}.
Message id: {{ trigger.event.data.message.message_id }}.
Data: {{ trigger.event.data.data|replace("_", "\_") }}
Keyboard editor:
- alias: "Telegram bot that edits the keyboard"
triggers:
- trigger: event
event_data:
command: "/remove_button"
actions:
message: "Callback received for editing the inline keyboard!"
- action: telegram_bot.edit_replymarkup
message_id: "last"
inline_keyboard:
Only acknowledges the ‘NO’ answer:
- alias: "Telegram bot that simply acknowledges"
triggers:
- trigger: event
event_data:
command: "/do_nothing"
actions:
message: "OK, you said no!"
Telegram callbacks also support arguments and commands the same way as normal messages.
- alias: "Telegram bot repeats arguments on callback query"
triggers:
- trigger: event
event_data:
command: "/repeat"
actions:
show_alert: true
message: "I repeat: {{trigger.event.data['args']}}"
In this case, having a callback with /repeat 1 2 3
will pop a notification saying I repeat: [1, 2, 3]
Receiving chat_id
and message_id
identifiers of sent messages by the telegram_bot
- alias: 'Notifications about messages sent by Telegram bot'
triggers:
- trigger: event
event_type: telegram_sent
event_data:
message_tag: "msg_start"
actions:
- action: input_number.set_value
data_template:
entity_id: input_number.chat_id
value: "{{ trigger.event.data.chat_id }}"
data_template:
entity_id: input_number.message_id
value: "{{ trigger.event.data.message_id }}"
Example: send_message with formatted Text
actions:
- action: notify.telegrambot
title: Example Message
message: 'Message with *BOLD*, _ITALIC_ and `MONOSPACE` Text'
Example: send_message with message tag
actions:
message: "Message with tag"
message_tag: "example_tag"
Example: send_message with disabled webpage preview
actions:
message: >-
<a href="https://www.home-assistant.io/">HA site</a>
parse_mode: html
disable_web_page_preview: true
Example: send_message to a topic within a group
actions:
message: "Message to a topic"
message_thread_id: 123
Example: automation to send a message and delete after a delay
alias: telegram send message and delete
sequence:
message: testing
response_variable: response
- delay:
seconds: 5
- repeat:
sequence:
- action: telegram_bot.delete_message
message_id: "{{ repeat.item.message_id }}"
chat_id: "{{ repeat.item.chat_id }}"
for_each: "{{ response.chats }}"
menu. Then, select Delete.
