System Bridge
System Bridge
Version
This integration requires System Bridge 4.0.2 and above. Any older version will not work.
Token
You will need your token. For instructions on finding your token, follow the steps in the System Bridge documentation
To add the System Bridge device to your Home Assistant instance, use this My button:
System Bridge can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select System Bridge.
Binary sensors
This integration provides the following binary sensors:
Name | Description |
Battery Is Charging | Whether the battery is charging |
Camera In Use | Whether the camera/webcam is in use |
Pending Reboot | Whether a reboot is pending |
New Version Available | Whether a new version is available |
Sensors
This integration provides the following sensors:
Battery | Battery level of the device |
Boot Time | Time the device was turned on |
CPU Speed | The current CPU speed |
Displays Connected | Number of displays connected |
Display Resolution X | Display resolution (across) |
Display Resolution Y | Display resolution (down) |
Display Refresh Rate | Display refresh rate |
Filesystem(s) | Space used for each drive letter / filesystem mount |
GPU Memory Free | GPU memory free in GB |
GPU Usage % | GPU usage percentage |
Kernel | Version information of the Kernel |
Latest Version | System Bridge Latest Version |
Load | System load percentage |
Memory Free | Memory (RAM) free in GB |
Memory Used | Memory (RAM) used in GB |
Memory Used % | Memory (RAM) % used |
Operating System | Version information of the Operating System |
Processes | Shows count of processes on the system |
Version | System Bridge Version |
These sensors are also available, but are not enabled by default:
CPU Temperature | The current temperature of the CPU |
CPU Voltage | The current voltage of the CPU |
GPU Core Clock Speed | GPU core clock speed in MHz |
GPU Memory Clock Speed | GPU memory clock speed in MHz |
GPU Fan Speed | GPU fan speed percentage |
GPU Memory Used | GPU memory used in GB |
GPU Memory Used % | GPU memory used percentage |
GPU Power Usage | GPU power usage |
GPU Temperature | The current temperature of the GPU |
Media player
The integration also provides a media player. This allows you control the currently playing media on your device.
This is currently only supported devices running System Bridge on Windows.
Media source
This integration is available as a media source to use with the media browser integration. You can browse and view media from your system to media players such as your web browser and other supported media players.
Update
The integration provides an update component, which will notify you when a new version of the app is available.
Actions
Notifications notify.system_bridge_hostname
You can send notifications to the device using the notify
platform.
action: notify.system_bridge_hostname
image: "https://brands.home-assistant.io/system_bridge/[email protected]"
timeout: 30
actions:
- command: api
endpoint: open
method: POST
body:
url: "http://homeassistant.local:8123/lovelace/cameras"
label: "Open Cameras"
audio:
source: "https://d3qhmae9zx9eb.cloudfront.net/home/amzn_sfx_doorbell_chime_02.mp3"
volume: 80
title: "Test Title"
message: "This is a message"
Parameters
Parameter | Description |
target | The target to send the notification to. This can be ignored. |
title | The title of the notification. |
message | The message of the notification. |
data | The data to send to the device. See below for info. |
Actions (data parameter)
This is an array of actions that can be sent to the device. These are buttons that show below the title, message and image.
command | The command to send to the device. For example api will send a request to the System Bridge API. |
label | The label of the button. |
data | The data to send to the device. The available parameters for the api command are: endpoint , method body , params . |
Here is an example action that will open a URL in the device’s browser:
- command: api
endpoint: open
method: POST
body:
Audio (data parameter)
This is an object containing the source
and volume
(0-100). The source must be a URL to a playable audio file (an MP3 for example).
Action system_bridge.get_process_by_id
Returns a process by its pid.
Show action in your Home Assistant instance.
action: system_bridge.get_process_by_id
bridge: "deviceid"
This returns Response Data like the following:
cpu_usage: 0.9
created: 1698951361.6117153
memory_usage: 0.23782578821487121
path: C:\Program Files (x86)\Steam\steam.exe
status: running
username: hostname\user
working_directory: null
Action system_bridge.get_processes_by_name
Returns a count and a list of processes matching the name provided.
action: system_bridge.get_processes_by_name
bridge: "deviceid"
count: 1
processes:
- id: 11196
cpu_usage: 0.3
created: 1698951365.770648
memory_usage: 0.07285296297215042
path: C:\Users\user\AppData\Local\Discord\app\Discord.exe
status: running
Action system_bridge.open_path
Open a URL or file on the server using the default application.
action: system_bridge.open_path
bridge: "deviceid"
path: "C:\\image.jpg"
type: OPENED
path: C:\image.jpg
message: Path opened
Action system_bridge.open_url
action: system_bridge.open_url
bridge: "deviceid"
url: "https://home-assistant.io"
type: OPENED
url: https://home-assistant.io
message: URL opened
Actionsystem_bridge.send_keypress
Send a keypress to the server.
action: system_bridge.send_keypress
bridge: "deviceid"
key: "a"
type: KEYBOARD_KEY_PRESSED
key: a
message: Key pressed
Action system_bridge.send_text
Sends text for the server to type.
action: system_bridge.send_text
bridge: "deviceid"
text: "Hello"
type: KEYBOARD_TEXT_SENT
text: Hello
message: Text entered
Action system_bridge.power_command
Sends power command to the system.
Supported commands are:
hibernate
lock
logout
restart
shutdown
sleep
action: system_bridge.power_command
bridge: "device"
command: "sleep"
type: POWER_SLEEPING
data: {}
message: Sleeping
