Sony Projector
The sony_projector
switch platform allows you to control the state of SDCP compatible network-connected projectors from Sony
To use your Sony Projector in your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
switch:
- platform: sony_projector
host: "192.168.1.47"
Under your projector’s web interface Advanced Menu, you may need to:
- Enable/start the PJ Talk service.
- Add the IP of your Home Assistant server to the Host Address field.
