Sky Hub
The sky_hub
integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] offers presence detection by looking at connected devices to a Sky Hub router
To use your Sky Hub device in your installation, add the following to your configuration.yaml
device_tracker:
- platform: sky_hub
