Niko Home Control
The niko_home_control integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to integrate your Niko Home Control into Home Assistant.
To enable this lights, add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
light:
  - platform: niko_home_control
    host: IP_ADDRESS
host string (Optional)
The IP address of the Niko Home light.
