Mobile App
The Mobile App integration allows Home Assistant mobile apps to easily integrate with Home Assistant.
If you are planning to use a mobile application that integrates with Home Assistant, we recommend that you keep this integration enabled.
If you are a mobile app developer, see the developer documentation for instructions on how to build your app on top of the mobile app component.
This integration is by default enabled, unless you’ve disabled or removed the default_config:
line from your configuration. If that is the case, the following example shows you how to enable this integration manually:
mobile_app:
Apps that use Mobile App
Home Assistant for iOS
(official) -
Beta release
(Testflight)
Beta release
Home Assistant for Android
(official)
