Météo-France
The meteo_france
integration uses the meteorological data from Météo-France
The integration support the following platforms within Home Assistant:
It displays the current weather along with a 5 days forecast and create sensors, including weather alerts and 1 hour rain forecast when available.
To add the Météo-France integration to your Home Assistant instance, use this My button:
From the list, select Météo-France.
Weather platform
To be used with the weather dashboard card to access current condition, today and next four days (default) or hours forecast.
Sensor platforms
All the following sensors will be created :
Entity | Description | Enabled by default |
cloud |
The current cloud cover in % | Yes |
daily_original_condition |
The daily original weather condition | No |
freeze_chance |
Probability of temperature below 0°C in the following hours | Yes |
next_rain |
Datetime of the next rain if expected within the next hour (see note below) | Yes |
The current original weather condition | No |
precipitation |
Precipitation cumulation for next 24 hours in mm | Yes |
pressure |
The current pressure in hPa | No |
rain_chance |
Probability of rain in the following hours | Yes |
snow_chance |
Probability of snow for the following hours | Yes |
temperature |
The current temperature in °C | No |
uv |
The current UV index | Yes |
weather_alert |
Weather alert status (see note below) | Yes |
wind_gust |
The current wind gust speed in km/h | No |
wind_speed |
The current wind speed in km/h | No |
Warning: The probability entities data are not always provided by the API. They are added only if available.
To enable an entity disabled by default, go in Settings -> Devices & services, click on the city name in Météo-France and then the X entities link. You will have the list of the enabled entities. Here click the filter button and select Show disable entities. The disabled entities will be visible in the list, select the one you want to enable and click the Enable Selected button.
About next_rain condition sensor
The 1 hour rain forecast is supported for more than 75 % of metropolitan France.
The attributes allow to have a forecast of the rain type by 5 to 10 minutes intervals:
forecast_time_ref
give a timestamp in ISO format UTC, corresponding to the start of the forecast. -
1_hour_forecast
is a dictionary to access the type of rain for the next hour for each periods.
“Type of rain” values are given by Météo-France API. Values already noted are:
Temps sec
Pluie faible
Pluie modérée
Pluie forte
Example:
forecast_time_ref: '2020-08-20T19:25:00+00:00'
1_hour_forecast:
0 min: Temps sec
5 min: Temps sec
10 min: Temps sec
15 min: Temps sec
20 min: Temps sec
25 min: Pluie faible
35 min: Pluie faible
45 min: Pluie modérée
55 min: Pluie modérée
About weather_alert sensor
The weather alert is available for the metropolitan France and Andorre.
The weather_alert
sensor state give the current weather alert status for the department linked to the city. Only one entity by department is created.
The sensor attributes give access to each type of alerts raised by Météo-France.
