Media source
The Media source integration platform allows integrations to expose media for use inside Home Assistant through the Media Browser panel or through supported media players like Google Cast.
This integration is configured automatically through default_config or if another integration implements a media source.
If your configuration does not contain any of the above, you can add the below to your configuration file:
media_source:
Local media
By default, the integration looks for media in a specified folder. If other media_dirs are not declared you need to use /media/local path for example in companion app notification.
For Home Assistant OS, Supervised and Container users, this folder is by default configured in the path /media.
Home Assistant OS and Supervised users can access this folder by using, for example, the Samba add-on. Users of Home Assistant Container can mount a volume of their choice to /media.
If you are a Home Assistant Core user, the default directory called is called media under the configuration path (where your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] is located).
Files served from media are protected by Home Assistant authentication unlike those served from www.
Using custom or additional media folders
It is also possible to set up custom and additional media directories. To do so, you’ll need to adjust the core configuration.
This example makes two different folders available to the integration:
homeassistant:
  media_dirs:
    local: /media
    recording: /mnt/recordings
If you want to use media from a network storage, the network storage must be connected first. Refer to these instructions on how to connect network storage.
The media from the network storage is then automatically added to the local media browser.
Playing media from a media source
To play media from a media source via a service call, use the uri scheme media-source://media_source/<media_dir>/<path>. Default media_dir is local.
Web browsers and Google Cast media players have very limited video container and codec support. The media source integration does not do any transcoding of media, meaning media files must be natively supported by your media player or web browser (for playing in the frontend).
If a video file is not supported by your media player or web browser it will fail to play. Please check the documentation of your media player or web browser for lists of supported video formats.
Example:
service: media_player.play_media
  entity_id: media_player.living_room_tv
  media_content_type: "video/mp4"
  media_content_id: "media-source://media_source/local/videos/favourites/Epic Sax Guy 10 Hours.mp4"
