Kostal Plenticore Solar Inverter
The Kostal Plenticore integration allows you to get data from Kostal Plenticore solar inverters and integrate them into your Home Assistant installation. It allows you also to change some of settings values of the inverter.
The integration uses the REST-API interface which is also used by the integrated Web-UI and therefore uses the same password.
To add the Kostal Plenticore Solar Inverter integration to your Home Assistant instance, use this My button:
  • From the list, select Kostal Plenticore Solar Inverter.
Sensors
The integration disables most of the sensors per default. You can enable it in the Entity page. The sensors are split into two sets, one for the process data and one for the setting values.
Note
The Plenticore inverter provides much more data endpoints, some of them are also dependent of the version of the firmware. If you are missing process data values, open an issue with the necessary information or make an pull request.
Process Data Sensors
The following sensors are available in the library:
Name Unit Description
Inverter State State of the inverter.
Solar Power W Sum of all DC strings (including battery).
Grid Power W Power from (+)/to (-) the grid.
Home Power from Battery W Power from the battery for home consumption.
Home Power from Grid W Power from the grid for home consumption.
Home Power from PV W Power from the PV for home consumption.
Home Power W Power used for home consumption.
AC Power W Output power of the inverter.
DC1 Power W Power of string 1.
DC2 Power W Power of string 2.
DC3 Power W Power of string 3.
DC1 Voltage V Voltage of string 1.
DC2 Voltage V Voltage of string 2.
DC3 Voltage V Voltage of string 3.
DC1 Current A Current of string 1.
DC2 Current A Current of string 2.
DC3 Current A Current of string 3.
PV to Battery Power W Power used to charge the battery.
Energy Manager State State of the energy manager.
Battery Cycles Number of full charge/discharge cycles.
Battery Power W Power from (+)/to (-) the battery.
Battery SoC % SoC of the Battery.
Autarky Day % Autarky of the current day.
Autarky Month % Autarky of the current month.
Autarky Year % Autarky of the current year.
Autarky Total % Autarky total.
Own Consumption Rate Day % Own consumption rate of the current day.
Own Consumption Rate Month % Own consumption rate of the current month.
Own Consumption Rate Year % Own consumption rate of the current year.
Own Consumption Rate Total % Own consumption rate total.
Home Consumption Day kWh Home energy consumption of the current day.
Home Consumption Month kWh Home energy consumption of the current month.
Home Consumption Year kWh Home energy consumption of the current year.
Home Consumption Total kWh Home energy consumption total.
Home Consumption from Battery Day kWh Home energy consumption from the battery of the current day.
Home Consumption from Battery Month kWh Home energy consumption from the battery of the current month.
Home Consumption from Battery Year kWh Home energy consumption from the battery of the current year.
Home Consumption from Battery Total kWh Home energy consumption from the battery total.
Home Consumption from Grid Day kWh Home energy consumption from the Grid of the current day.
Home Consumption from Grid Month kWh Home energy consumption from the Grid of the current month.
Home Consumption from Grid Year kWh Home energy consumption from the Grid of the current year.
Home Consumption from Grid Total kWh Home energy consumption from the Grid total.
Home Consumption from PV Day kWh Home energy consumption from the PV of the current day.
Home Consumption from PV Month kWh Home energy consumption from the PV of the current month.
Home Consumption from PV Year kWh Home energy consumption from the PV of the current year.
Home Consumption from PV Total kWh Home energy consumption from the PV total.
Energy PV1 Day kWh Energy of PV string 1 of the current day.
Energy PV1 Month kWh Energy of PV string 1 of the current month.
Energy PV1 Year kWh Energy of PV string 1 of the current year.
Energy PV1 Total kWh Energy of PV string 1 total.
Energy PV2 Day kWh Energy of PV string 2 of the current day.
Energy PV2 Month kWh Energy of PV string 2 of the current month.
Energy PV2 Year kWh Energy of PV string 2 of the current year.
Energy PV2 Total kWh Energy of PV string 2 total.
Energy PV3 Day kWh Energy of PV string 3 of the current day.
Energy PV3 Month kWh Energy of PV string 3 of the current month.
Energy PV3 Year kWh Energy of PV string 3 of the current year.
Energy PV3 Total kWh Energy of PV string 3 total.
Energy Yield Day kWh Energy yield of the current day.
Energy Yield Month kWh Energy yield of the current month.
Energy Yield Year kWh Energy yield of the current year.
Energy Yield Total kWh Energy yield total.
Energy Discharge to Grid Day kWh Energy discharged from battery to the Grid of the current day.
Energy Discharge to Grid Month kWh Energy discharged from battery to the Grid of the current month.
Energy Discharge to Grid Year kWh Energy discharged from battery to the Grid of the current year.
Energy Discharge to Grid Total kWh Energy discharged from battery to the Grid total.
Battery Charge from Grid Day kWh Energy charged to the battery from the Grid of the current day.
Battery Charge from Grid Month kWh Energy charged to the battery from the Grid of the current month.
Battery Charge from Grid Year kWh Energy charged to the battery from the Grid of the current year.
Battery Charge from Grid Total kWh Energy charged to the battery from the Grid total.
Battery Charge from PV Day kWh Energy to the battery on the DC side charged by PV during the current day.
Battery Charge from PV Month kWh Energy to the battery on the DC side charged by PV during the current month.
Battery Charge from PV Year kWh Energy to the battery on the DC side charged by PV during the current year.
Battery Charge from PV Total kWh Energy to the battery on the DC side charged by PV total.
Battery Discharge Day kWh Energy from the battery on the DC side discharged during the current day.
Battery Discharge Month kWh Energy from PV on DC-side used to charge the battery of the current month.
Battery Discharge Year kWh Energy from PV on DC-side used to charge the battery of the current year.
Battery Discharge Total kWh Energy from PV on DC-side used to charge the battery total.
Energy to Grid Day kWh Energy fed into the grid for the current day.
Energy to Grid Month kWh Energy fed into the grid for the current month.
Energy to Grid Year kWh Energy fed into the grid for the current year.
Energy to Grid Total kWh Energy fed into the grid in total, since the system was installed.
Sum power of all PV DC inputs W Total sum of power provided by all PV inputs together.
Note
The inverter does not provide any data about the energy that is fed into the grid directly, but the pykoplenti library provides it via virtual process data.
Configuration of the energy dashboard
The following sensors can be used in the energy dashboard:
Energy dashboard Sensor
Grid consumption Home Consumption from Grid Total
Solar production Energy PV1 Total, Energy PV2 Total, Energy PV3 Total
Battery systems Battery Discharge Total, Battery Charge from PV Total
Note
Some of the energy is measured on the DC side and some on the AC side, so the values may differ slightly due to losses between DC and AC.
Settings Sensors
Name Unit RW Description
Battery Dynamic SoC RW Dynamic SoC.
Battery Smart Control RW Enable smart battery control
Battery Strategy RW Battery strategy.
Shadow Management RW PV string shadow management.
Note
Setting values change less often, therefore these sensors are only polled every 5 minutes.
Battery Strategy
This sensor is on by default, which maps to the “Automatically” mode in the Kostal Plenticore Plus documentation. This mode is recommended for regions with little snowfall.
Turning this sensor off maps to the “Automatically economical” mode. Consequently, the inverter controls the battery charging automatically but switches the battery off when there is insufficient PV energy to charge the battery for longer periods. This mode is recommended for regions with a lot of snowfall.
The Battery Smart Control sensor appears as a select field labeled “Battery Charging / Usage Mode” with three options:
  • None: the battery is loaded immediately when there is PV energy spare.
  • Battery:SmartBatteryControl:Enable: the battery loading optimizes grid feed-in and battery loading. This setting is recommended when the grid feed-in is limited to, for example, 70% of the Plenticore Plus peak power.
  • Battery:TimeControl:Enable: battery charging/discharging can be configured flexibly at different times (tariff periods). Detailed settings must be done on the web frontend of the Kostal Plenticore Plus inverter. This option activates the time-controlled battery usage mode.
Number
The following Number entities are available. The values could also be change from Home Assistant.
Battery min Home Consumption W RW Min. home consumption power for battery.
Battery min SoC % RW Min. SoC of battery.
