HDMI-CEC
The hdmi_cec
integration provides actions that allow selecting the active device, powering on all devices, setting all devices to standby and creates switch entities for HDMI devices. Devices are defined in the configuration file by associating HDMI port number and a device name. Connected devices that provide further HDMI ports, such as sound-bars and AVRs are also supported. Devices are listed from the perspective of the CEC-enabled Home Assistant device. Any connected device can be listed, regardless of whether it supports CEC. Ideally the HDMI port number on your device will map correctly the CEC physical address. If it does not, use cec-client
(part of the libcec
package) to listen to traffic on the CEC bus and discover the correct numbers.
CEC Setup
Home Assistant OS
To test if HDMI-CEC will work on your Home Assistant OS installation, you can use the official CEC Scanner add-on. Run this add-on to see if your hardware has HDMI-CEC capabilities and which devices are connected. Do not have this add-on Start on boot as it will interfere with the integration.
Once you’ve run the add-on, you can use the resulting scan information to configure the integration.
Adapter
The computer running Home Assistant must support CEC, and of course be connected via HDMI to a device also supporting CEC. You can purchase a USB CEC adapter
libcec
This section only applies to users of Home Assistant Core in a Python virtual environment.
libceclibcec
installs Python 3 bindings by default as a system Python module. If you are running Home Assistant in a Python virtual environment, make sure it can access the system module, by either symlinking it or using the --system-site-packages
flag.
Symlinking into virtual environment
Create a symlink to the cec
installation including the _cec.so file. Keep in mind different installation methods will result in different locations of cec.
ln -s /path/to/your/installation/of/cec.py /path/to/your/venv/lib/python*/site-packages
ln -s /path/to/your/installation/of/_cec.so /path/to/your/venv/lib/python*/site-packages
Symlinking examples
For the default virtual environment of a Manual install for Raspberry Pi the command would be as follows.
ln -s /usr/local/lib/python*/dist-packages/cec.py /srv/homeassistant/lib/python*/site-packages
ln -s /usr/local/lib/python*/dist-packages/_cec.so /srv/homeassistant/lib/python*/site-packages
If after symlinking and adding hdmi_cec:
to your configuration you are getting the following error in your logs,
* failed to open vchiq instance
you will also need to add the user account Home Assistant runs under, to the video
group. To add the Home Assistant user account to the video
group, run the following command. $ usermod -a -G video <hass_user_account>
Testing your installation
- Login to Raspberry Pi
ssh pi@your_raspberry_pi_ip
- at the command line type:
echo scan | cec-client -s -d 1
Note: to use this command you have to install cec-utils package. In Debian based should be: sudo apt install cec-utils
- This will give you the list of devices that are on the bus
opening a connection to the CEC adapter...
requesting CEC bus information ...
CEC bus information
device #4: Playback 1
address: 3.0.0.0
active source: no
vendor: Sony
osd string: BD
CEC version: 1.4
power status: on
language: ???
address:
entry above this will be used to configure Home Assistant, this address is represented below as 3: BlueRay player.
Configuration Example
In the following example, a Pi Zero running Home Assistant is on a TV’s HDMI port 1. HDMI port 2 is attached to a AV receiver. Three devices are attached to the AV receiver on HDMI ports 1 through 3.
You can use either direct mapping name to physical address of device
hdmi_cec:
devices:
TV: 0.0.0.0
Pi Zero: 1.0.0.0
Fire TV Stick: 2.1.0.0
Chromecast: 2.2.0.0
Another Device: 2.3.0.0
BlueRay player: 3.0.0.0
or port mapping tree:
hdmi_cec:
devices:
1: Pi Zero
2:
1: Fire TV Stick
2: Chromecast
3: Another Device
3: BlueRay player
Choose just one schema. Mixing both approaches is not possible.
Another option you can use in configuration is platform
which specifying of default platform of HDMI devices. “switch” and “media_player” are supported. Switch is default.
hdmi_cec:
platform: media_player
Then you set individual platform for devices in customizations:
hdmi_cec:
types:
hdmi_cec.hdmi_5: media_player
And the last option is host
. PyCEC supports bridging CEC commands over TCP. When you start pyCEC on machine with HDMI port (python -m pycec
), you can then run Home Assistant on another machine and connect to CEC over TCP. Specify TCP address of pyCEC server:
hdmi_cec:
host: 192.168.1.3
Actions
Select Device
Use the hdmi_cec.select_device
action with the name of the device from configuration or entity_id or physical address”to select it, for example:
{"device": "Chromecast"}
{"device": "switch.hdmi_3"}
{"device": "1.1.0.0"}
So an Automation action using the example above would look something like this.
actions:
- action: hdmi_cec.select_device
device: Chromecast
Power On
Use the hdmi_cec.power_on
action (no arguments) to power on any devices that support this function.
An Automation action using the example above would look something like this.
actions:
- action: hdmi_cec.power_on
Standby
Use the hdmi_cec.standby
action (no arguments) to place in standby any devices that support this function.
actions:
- action: hdmi_cec.standby
Change volume level
Use the hdmi_cec.volume
action with one of following commands:
Volume up
Increase volume three times:
{"up": 3}
Keep increasing volume until release is called:
{"up": "press"}
Stop increasing volume:
{"up": "release"}
Volume down
Decrease volume three times:
{"down": 3}
Keep decreasing volume until release is called:
{"down": "press"}
Stop decreasing volume:
{"down": "release"}
Volume mute
Toggle mute:
{"mute": ""}
value is ignored.
