GeoRSS
The geo_rss_events integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] retrieves events from a GeoRSS feed and shows information of those events filtered by distance to Home Assistant’s location and grouped by category.
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] is particularly useful if events occur unexpectedly in the vicinity of the home while the GeoRSS feed also contains many events representing distant unrelated entries. Typical examples are bush fires alerts or earthquakes.
The reference point for comparing the distance is by default defined by latitude and longitude in the basic configuration.
Only entries of the feed are considered that define a location as point or polygon in georss.org format or as WGS84 latitude/longitude.
The data is updated every 5 minutes.
To enable the GeoRSS events sensor, add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. This is an example configuration showing bush fire incidents from the NSW Rural Fire Service. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
  - platform: geo_rss_events
    name: NSW Fire Service
    url: https://www.rfs.nsw.gov.au/feeds/majorIncidents.xml
    unit_of_measurement: "Incidents"
    categories:
      - 'Emergency Warning'
      - 'Watch and Act'
      - 'Advice'
url string Required
Full URL of the GeoRSS feed.
name string (Optional, default: Event Service)
Name of the sensor used in generating the entity id.
latitude string (Optional)
Latitude of the coordinates around which events are considered.
Default:
Latitude defined in your configuration.yaml
longitude string (Optional)
Longitude of the coordinates around which events are considered.
Default:
Longitude defined in your configuration.yaml
radius string (Optional, default: 20km)
The distance in kilometers around the Home Assistant’s coordinates in which events are considered.
categories list (Optional)
List of event category names found in the GeoRSS feed. A separate sensor is created for each category defined.
Default:
Default is to join events from all categories into an ‘Any’ category.
unit_of_measurement string (Optional, default: Events)
The type of events found in the GeoRSS feed.
Example Feeds
Bush Fire Alerts
    name: Qld Fire and Emergency Services
    url: https://www.qfes.qld.gov.au/data/alerts/bushfireAlert.xml
    unit_of_measurement: "Alerts"
    url: https://alert.tas.gov.au/data/incidents-and-alerts.xml
    name: WA Department of Fire and Emergency Services
    url: https://www.emergency.wa.gov.au/data/incident_FCAD.rss
    name: ACT Emergency Services Agency
    url: https://www.esa.act.gov.au/feeds/currentincidents.xml
Earthquake Alerts
    name: USGS All Earthquakes
    url: https://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.atom
    categories:
      - 'Past Hour'
      - 'Past Day'
    name: BGS Worldwide Earthquakes
    url: http://earthquakes.bgs.ac.uk/feeds/WorldSeismology.xml
    categories:
      - 'EQMH'
    name: Recent significant earthquake reports (Canada)
    url: https://www.earthquakescanada.nrcan.gc.ca/cache/earthquakes/canada-en.atom
    categories:
      - 'Earthquake Report'
