Frontier Silicon
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides support for Internet Radios based on the Frontier Silicon chipset. Some of the manufacturers which offer products based on these chips include: Hama, Medion, Slivercrest, Auna, Technisat, Revo, Pinnel, etc. These devices will be usually controlled by the OKTIV or UNDOK apps.
Supported models
Frontier Silicon is used by many different brands of radio manufacturers.
Supported devices include, but are not limited to:
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] was developed and tested with a Roberts Stream 94i.
If your device is supported by the OKTIV or UNDOK apps, then it is also supported by this integration.
The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] supports automatic discovery of your Internet Radio. If you need to set up the device manually, please provide the device IP-address. Some models use a separate port (2244) for API access, this can be verified by visiting http://[host]:[port]/device.
The default PIN for Frontier Silicon-based devices is 1234. You can set the PIN code of your device (depending on manufacturer) under: MENU button > Main Menu > System setting > Network > NetRemote PIN setup
To add the Frontier Silicon integration to your Home Assistant instance, use this My button:
Frontier Silicon can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Frontier Silicon.
In case your device (friendly name) is called badezimmer, an example automation can look something like this:
# Example configuration.yaml automation
alias: "Bathroom Motion Detected"
triggers:
  - trigger: state
    entity_id: binary_sensor.motion_sensor_166d0001171111
    to: "on"
actions:
  - action: media_player.turn_on
      entity_id: "media_player.badezimmer"
Screenshots:
Overview DAB+ (Badezimmer) and Spotify (Küche):
Overview of the info dialog:
Notes and Limitations
Warning
Some older devices may require setting up a session to process requests. This is automatically detected by the underlying library. There is always a single user (session) controlling a device, which means that once Home Assistant connects to a device all other sessions will be invalidated.
This renders the usage of [UNDOK] almost impossible for these older devices, as the Home Assistant integration polls the device state every 30 seconds or issues a command by creating a new session. In that case, you have to disable the integration if you want to use UNDOK.
