Emulated Kasa
The Emulated Kasa integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] emulates a TP-Link Kasa smart plug and announces the power usage of configured devices to any that might request it on the local network.
For example, the Sense Energy Monitor can use this to identify power usage.
The configuration includes a list of entities to expose with attributes for the published name and current power usage. If the entity is a sensor, that value will be reported as the current power usage unless the power field is defined. The power field can contain a hardcoded value, a sensor, or a template (see configuration example).
The provided power unit must be the current power usage in Watts. Values of kW
can be converted, but the values of kWh
cannot be used.
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] requires the entities exposed to be listed in your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes.
emulated_kasa:
entities:
light.dining_room:
power: 40.2
A list of entities exposed.
The current power usage in watts. This can be set to a static value or a template.
A full configuration sample looks like the one below.
emulated_kasa:
entities:
# uses the sensor state value
sensor.power_meter:
# uses static value
light.dining_room:
name: "Dining Room Lights"
power: 40.2
# uses template based on state of device
fan.ceiling_fan:
power: >-
{% if is_state_attr('fan.ceiling_fan','speed', 'low') %} 2
{% elif is_state_attr('fan.ceiling_fan','speed', 'medium') %} 12
{% elif is_state_attr('fan.ceiling_fan','speed', 'high') %} 48
{% endif %}
# uses value from 3rd party sensor
light.wled:
power_entity: sensor.light_power_w
# uses template to convert device state into watts
sensor.ups_kw:
power: "{{ float(states('sensor.ups_kw')) * 1000 }}"
