Dlib Face Identify
The dlib_face_identify
image processing integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to use the Dlib
For using the result inside an automation rule, take a look at the integration page.
This integration is only available on Home Assistant Core installation types. Unfortunately, it cannot be used with Home Assistant OS, Supervised or Container.
To enable Dlib Face Identify, add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
image_processing:
- platform: dlib_face_identify
source:
- entity_id: camera.door
faces:
Jon: /home/hass/jon.jpg
Bob: /home/hass/bob.jpg
If the platform fails to load because it could not install its requirement, install cmake: sudo apt-get install cmake
