Dlib Face Detect
The dlib_face_detect
image processing integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to use the Dlib
This can be used to trigger an automation rule. Further info is on the integration page.
This integration is only available on Home Assistant Core installation types. Unfortunately, it cannot be used with Home Assistant OS, Supervised or Container.
To enable Dlib Face Detect, add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
image_processing:
- platform: dlib_face_detect
source:
- entity_id: camera.door
