Cisco Webex Teams
The cisco_webex_teams
notification platform allows you to deliver rich notifications from Home Assistant to Cisco Webex Teams (formerly known as Cisco Spark).
To use this notification platform you will need an app (bot) token. To obtain a token visit Cisco Webex for Developers.
- Detailed instructions can be found in the section titled Creating a Webex Teams Bot on the Webex Teams bot documentation.
You also need to specify the room_id
that you wish to post messages into. The room_id
can be found in one of two ways:
- Logging in at Cisco Webex for Developers and navigate to
Documentation
>API Reference
>Messages
and select List Messages, or - Log into the web client at teams.webex.com,
- select the room (or create a new room),
- then copying the room ID from the URL.
You must add the bot email (in the format [email protected]
) as a participant to the room specified above.
To enable this platform in your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.
[Learn more] file.
[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
notify:
- name: NOTIFIER_NAME
platform: cisco_webex_teams
token: YOUR_BOT_TOKEN
room_id: CISCO_WEBEX_TEAMS_ROOMID
Rich Text Formatting
Webex Teams clients can render rich text via a whitelisted set of html tags.
For example, you could configure automations to display details in an easy to read fashion like so:
Rich text as displayed in the macOS client.
Here are the automations for the above screenshot:
# Rich Text Example 1.
# Show a one line message with a red banner
- alias: "Notify On Build Failing"
trigger:
- platform: webhook
webhook_id: build_failed
action:
service: notify.cisco_webex_teams_notify
message: "<blockquote class=danger>Build 0.89.5 compile failed."
# Rich Text Example 2.
# Show a title and multi-line message with a yellow banner,
# with lists, a person mention and a link
- alias: "Notify On Build Unstable"
trigger:
- platform: webhook
webhook_id: build_unstable
action:
title: "<strong>Build 0.89.6 is unstable.</strong>"
message: "<blockquote class=warning>Version 0.89.6 failed verifications.
<ul>
<li> test_osx
<li> test_win_lint
<li>... and 4 more.
</ul>
<p><@personEmail:[email protected]></p>
<p><small><i>View <a href='https://demo/testReport/'>Test Report</a></i></small><br></p>
# Rich Text Example 3.
# Show a title and multi-line message with a blue banner,
- alias: "Notify On Build Passing"
trigger:
- platform: webhook
webhook_id: build_passed
action:
title: "<strong>✅ Version 0.89.7 passed all tests and deployed to production!</strong>"
message: "<blockquote class=info>Version 0.89.7 passed all verifications.
<ul>
<li> test_cov
<li> test_osx
<li> test_win
<li> test_linux
<li>... and 45 more.
</ul>
The following is a list of the allowed html tags and attributes:
Tag | More Info |
<@personEmail:[email protected]> |
Used to tag another Webex Team user by email address. |
<a> |
Defines a hyperlink. Allows attribute href . |
<blockquote> |
Defines a section that is quoted from another source. Allows attribute class with allowed values danger , warning , info , primary , secondary . |
<b> |
Defines bold text. |
<strong> |
Defines important text. |
<i> |
Defines italic text. |
<em> |
Defines emphasized text. |
<pre> |
Defines preformatted text. |
<code> |
Defines a piece of computer code. |
<br> |
Defines a single line break. |
<p> |
Defines a paragraph. |
<ul> |
Defines an unordered list. |
<ol> |
Defines an ordered list. |
<li> |
Defines a list item. |
<h1> to <h3>
Defines HTML headings. |
To use notifications, please see the getting started with automation page.
