BT Home Hub 5
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] offers presence detection by looking at connected devices to a BT Home Hub 5 based router.
To use a BT Home Hub 5 router in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
device_tracker:
  - platform: bt_home_hub_5
    host: 192.168.1.254
host string (Optional, default: 192.168.1.254)
The IP address of your router.
