RESTful binary sensor
The rest
binary sensor platform is consuming a given endpoint which is exposed
by a
RESTful API
of a device, an application, or a web service.
The binary sensor has support for GET and POST requests.
Tip: If you want to create multiple sensors
using the same endpoint, use the RESTful configuration instructions.
The JSON messages can contain different values like 1
, "1"
TRUE
, true
, on
, or open
. If the value is nested then use a
template.
"name": "Binary sensor",
"state": {
"open": "true",
"timestamp": "2016-06-20 15:42:52.926733"
To enable this sensor,
add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file for a GET request:
binary_sensor:
- platform: rest
resource: http://IP_ADDRESS/ENDPOINT
or for a POST request:
binary_sensor:
- platform: rest
method: POST
or a template based request:
binary_sensor:
- platform: rest
resource_template: "http://IP_ADDRESS/{{ now().strftime('%Y-%m-%d') }}"
The resource or endpoint that contains the value with template support.
Name of the REST binary sensor.
Defines a template for the icon of the entity.
Defines a template for the entity picture of the entity.
Defines a template if the entity state is available or not.
An ID that uniquely identifies this entity. This allows changing the name
, icon
and entity_id
from the web interface.
The headers for the requests.
The query params for the requests.
Examples
aREST sensor
Instead of using an aREST binary sensor, you could retrieve the value of a device supporting aREST directly with a REST binary sensor.
binary_sensor:
- platform: rest
resource: http://192.168.0.5/digital/9
method: GET
device_class: light
value_template: '{{ value_json.return_value }}'
Accessing an HTTP authentication protected endpoint
The REST sensor supports HTTP authentication and template-enabled customized headers.
binary_sensor:
- platform: rest
resource: http://IP_ADDRESS:5000/binary_sensor
username: ha1
password: test1
authentication: basic
headers:
User-Agent: Home Assistant
Content-Type: application/json
X-Custom-Header: '{{ states("input_text.the_custom_header") }}'
The headers will contain all relevant details. This will also give you the ability to access endpoints that are protected by tokens.
Content-Length: 1024
Host: IP_ADDRESS1:5000
Authorization: Basic aGExOnRlc3Qx
Accept-Encoding: identity
