Anel NET-PwrCtrl
The anel_pwrctrl switch platform allows you to control ANEL PwrCtrl devices on firmware 6.x and older. ANEL PwrCtrl devices on firmware 7.x are not supported.
Supported devices (tested):
  • PwrCtrl HUT
  • PwrCtrl Advanced
  • PwrCtrl Advanced Power
To add this platform to your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
switch:
  - platform: anel_pwrctrl
    host: IP_ADDRESS
    port_recv: PORT
    port_send: PORT
    username: USERNAME
    password: PASSWORD
host string (Optional)
The IP address or hostname of your PwrCtrl device.
port_recv integer Required
The port on which the device receives data.
port_send integer Required
The port from which the device sends data.
username string Required
The username for your device.
password string Required
The password for your device.
Note
If no host is given the platform will try to auto-discover all devices on the network, that are listening on the given port_recv.
