Telegram broadcast
Telegram implementation to support sending messages only. Your Home Assistant instance does not have to be exposed to the internet and there is no polling to receive messages or commands sent to the bot.
Information on how to send a message via the service telegram_bot.send_message
can be found here.
To integrate this into Home Assistant, add the following section to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file:
telegram_bot:
- platform: broadcast
api_key: YOUR_API_KEY
allowed_chat_ids:
- 123456789 # example id of a user
- -987654321 # example id of a group, starts with a -
A list of ids representing the users and group chats to which messages can be send. Default the message will be send to the first alllowed chat_id. By using the target
service data attribute the message can be send to other chat_ids from the list.
Default parser for messages if not explicit in message data, either html
or markdown
To get your chat_id
and api_key
follow the instructions here.
