SolarEdge Local
The solaredge_local
[Learn more] uses the local API available on some SolarEdge Inverters to allow you to get details from your SolarEdge solar power setup and integrate these into your Home Assistant installation.
Only specific models support the local API. The local API is available on inverters that do not have an LCD character screen. You can also check the datasheets if in the section “Additional Features”, sub-section “Inverter Commissioning” is present the following line “With the SetApp mobile application using built-in Wi-Fi access point for local connection”. These inverters also have a part number that ends with a 4. For example: SEXXK-XXXXXBXX4 or SEXXXXH-XXXXXBXX4
You can check if the local API works by finding the IP address of your inverter and visiting it in a browser. If it supports the local API, you’ll see an HTML page with the SolarEdge logo and a “Commissioning” menu.
Recent firmware updates have disabled the local API on many inverters. Please enter the IP address of your inverter in a browser before attempting to use this integration. If the local API is enabled, you’ll see a web page with the SolarEdge logo and a “Commissioning” menu. See this issue and this issue for additional details.
If your inverter does not support the local API, you can use the cloud based version
To use the SolarEdge integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] in your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more]
- platform: solaredge_local
ip_address: IP_ADDRESS
Full configuration sample
A full configuration entry would look like the sample below.
ip_address: 192.168.1.123
