Russound RNET
The russound_rnet
[Learn more] allows you to control Russound devices that make use of the RNET protocol.
This has initially been tested against a Russound CAV6.6 unit with six zones and six sources. It will also work with a Russound CAA66, but be sure to use a null-modem cable. If you have mutiple controllers connected via the RNET link ports, every increment of 6 zones maps to the corresponding controller ID.
Connecting to the Russound device is only possible by TCP, you can make use of a TCP to Serial gateway such as tcp_serial_redirect
To add an integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] to your installation, add the following to your configuration.yaml
media_player:
- platform: russound_rnet
host: 192.168.1.10
port: 1337
zones:
1:
2:
3:
4:
5:
6:
# controller 2 - zone 1 (connected via RNET link ports)
7:
sources:
- name: Sonos
- name: Sky+
